Balance shaft belt adjuster bracket (Replacement Bolt)
Old Apr 9, 2008 | 05:38 PM
no1knows908's Avatar
Default Balance Shaft Selt Adjuster Bracket (Replacement Bolt)
I was doing my timing belt, water pump, ect., today and I broke off one of the bolts and I can't seem to get a replacement from Majestic... Part E-13. They have a listing for just 13 but I have no idea what E-13 means...
Old Apr 10, 2008 | 10:21 AM
Default Re: Balance Shaft Selt Adjuster Bracket (no1knows908)
Bump...
Old Apr 10, 2008 | 04:56 PM
gstrudler's Avatar
Don't know why they call it E-13 in the diagram. That's just the bolt that holds 13 to the block and lets it rotate. You could try calling a dealership for the PN and then search majestic, although you'd probably get it faster from the dealer and the part should only be a few bucks and you don't have to pay shipping, so it may even end up being cheaper.
Old Apr 10, 2008 | 10:59 PM
pentaq's Avatar
Default Re: Balance Shaft Selt Adjuster Bracket (gstrudler)
E-13 is the number of diagram. It's simply a reference to another diagram
Old Apr 11, 2008 | 12:27 PM
Default Re: Balance Shaft Selt Adjuster Bracket (pentaq)
Thanks, I figured that out at the dealer earlier, it was under the oil pump diagram...
SRd240sx
10
Oct 27, 2019 06:11 PM
methos713
May 5, 2008 12:29 AM
soon2bdropped
Apr 3, 2007 07:44 PM
1slow_si
Sep 20, 2004 02:39 PM
