Question on seam sealer?
Old Apr 9, 2008 | 05:29 PM
oneoffaccord's Avatar
Default Question on seam sealer?
Does the seam sealer have to be applied to bare metal or a primed service? The instructions dont list that. Im using sem seam sealer 39377. I know it a stupid question but i cant a answer.
Old Apr 9, 2008 | 07:56 PM
88civic's Avatar
Default Re: Question on seam sealer? (oneoffaccord)
if bare metal then prep well with red scotch brite then etch prime!
if on top of paint prep well with red scotch brite or 320 grit!
good luck!!!
Old Apr 9, 2008 | 08:18 PM
Default Re: Question on seam sealer? (88civic)
thanks alot, could i use it on a primed surface?
Old Apr 12, 2008 | 08:02 PM
88civic's Avatar
yes just prep it first! 320 or red scotch brite...
Old Apr 12, 2008 | 08:49 PM
what i did is primed the surface. let it dry then sand the primer with 120 grit. then applied the seam sealer. its fine
Old Apr 13, 2008 | 05:16 PM
goldex420's Avatar
i put it on the sealer. u dont have to sand or anything just put it on use some laquer thinner to smooth it out.
cubanboy
Paint and Body
19
Dec 16, 2023 04:31 PM
SyDuck
Aug 7, 2004 05:20 PM
Atheist
Nov 23, 2003 05:21 AM
Dark Halo
Oct 5, 2002 08:09 AM
loclowd
May 20, 2002 11:30 AM
