obd1 ECU in 00 Civic Si
Recently i bought a computer from phearable.net for my car which is an 0bd1, i put it in and worked fine, but 3 days ago i was replacing the oil pan gasket and i removed the headers(aftermarket) so i could do it, and then when i was finished and started the car the CEL came on and the idle was high. what could be the problem, or how can i read the DTCs?
no i forgot so i put the car up again and hooked it up real quick, unplugged the battery for a few mins. and started the car again but the light came back on and the idle went high again, i dont know why but every time i would shut the car off and start it again the light would take around 5 secs before it would come on and the idle would go to around 1500rpms
Make sure everything is hooked up the way it was before. Disconnect your battery for like 30 min. at least to be sure it's reset. If this doesn't work search how to check codes. Good luck!
bk7794
20
Aug 7, 2016 02:59 PM
See-Tee-R
Nov 15, 2010 07:14 PM
taimysho0
Sep 17, 2009 09:17 PM
