powerstreeing help
Old Apr 9, 2008 | 04:03 PM
ELhatch's Avatar
Default powerstreeing help
i need to know what kind of powerstreeing pump and hose i need for my gsr into my ek??
thanks guys.
Old Apr 9, 2008 | 04:52 PM
pdiggitydogg's Avatar
thanks for not searching
https://honda-tech.com/zerothread?id=1822781
Old Apr 9, 2008 | 06:33 PM
j_scobar's Avatar
Default Re: (pdiggitydogg)
Here's what I did for my swap. It came with the PS hose still attached to it and was cut off at the hose. I just went to the local Auto store and bought a 1/2" brass compression union for 6 bucks and I was done. Here's a quick write up on how to do it.
How to Adapt your existing Power Steering hose to the Pump with your GSR Swap
The tools you’ll need will be a Tubing Cutter and a Barrel Reamer or something rigid to ream sharp edges after you cut tubes. That, plus when you cut the tube it will make the Inside Diameter of the tube smaller, so the reamer will open it back up to the original size. In the picture is a barrel reamer (red), but anything that will take off the sharp edges of the cut tube will work (i.e. screwdriver). Be sure that when your cutting off your old hard tubes to leave as much of the straight tube as possible because you won’t get a good seal if the un-tightened union sits on a bend.
Old Apr 10, 2008 | 03:56 PM
ELhatch's Avatar
that doesn't help me....
Old Apr 10, 2008 | 10:51 PM
ek4_b16a's Avatar
Default Re: (ELhatch)
if your car never came with powersteering then you wouldn't be able to just do what you want....add a hose and a pump...you must have powersteering in order to have powersteering...if you already have powersteering then pdiggitydogg has your solution...click his link and read up...
Paul Elisha
Mar 4, 2012 11:38 AM
Akai Star
Apr 6, 2010 09:05 AM
MurdersV8s
Apr 18, 2008 08:12 PM
aleks77
Feb 29, 2008 08:46 AM
Stoich EG2
Welding / Fabrication
12
Apr 21, 2005 07:08 PM
