IAC code, car idles fine?
Old Apr 9, 2008 | 12:58 PM
jdmland's Avatar
Default IAC code, car idles fine?
Modified by jdmland at 4:38 PM 4/26/2008
Old Apr 9, 2008 | 01:03 PM
philosofy1's Avatar
Default Re: IAC code, car idles fine? (jdmland)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmland &raquo;</TD></TR><TR><TD CLASS="quote">I got a code 14, car won't idle, swapped iac's, car idles fine.
Problem is i'm still getting code 14, but there is no idle problem, car runs fine.
I reset the ecu, unplugged the battery, still same code, whats up?
This is a b18c swap , any help would be great guys, i searched, but they are all about fixing the iac, i already fixed it, i'm still getting code14?</TD></TR></TABLE>
how long did you disconnect the battery for and what side of the battery did you pull? +/-?
Old Apr 9, 2008 | 01:38 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmland &raquo;</TD></TR><TR><TD CLASS="quote">Gonna try a direct wire from plug A #9 is iacv, do i just ground the other wire to the body?</TD></TR></TABLE>
i wouldn't start messing with it like that.
this is what i can suggest. start the car, unplug the sensor, turn the car off, unplug the neagtive side of the battery, plug up the sensor again, leave the battery unplug for about 5 min, pug it back up start the car and see what happens then.
JDM_95_LS
Audio / Security / Video
May 19, 2007 07:33 AM
CR_VtecCRX89
17
Feb 22, 2005 07:17 PM
rtotakoori
Jul 26, 2004 03:55 PM
EE_Chris
Jun 7, 2004 09:25 PM
jolt-tsp
Honda S2000
May 10, 2004 11:35 AM
