Suspension & Brakes Theory, alignment, spring rates....
CIVIC LCA'S AND COILOVERS. HELP****
Old Apr 9, 2008 | 12:01 PM
da6er's Avatar
Default CIVIC LCA'S AND COILOVERS. HELP****
OK SO I KNOW THERES A DIFFERENCE FROM EG AND EK LCA'S
THE EK LCA IS A LIL SLIMER... I HAVE A COILOVER SET FOR A EG... I HEAR YOU CAN USE WASHERS TO MAKE UP FOR THE DIFFERENT THINKNESS AND IT WILL RUN FINE ON THE EK LCA...
IS THIS TRUE AND HAS ANYONE DONE THIS?
Old Apr 9, 2008 | 12:54 PM
JDMDAEK's Avatar
Default Re: CIVIC LCA'S AND COILOVERS. HELP**** (da6er)
ya the eg lca has some extra bushings where the strut bolts onto it. using eg struts on an ek can be done with spacers and the other way you cut the bushings off of the eg lca and ek struts will fit. Its really easy. or you can buy aftermarket lcas and they will fit either
Momentum
Suspension & Brakes
May 6, 2009 10:11 PM
oldskoolaccord
Jan 18, 2007 03:11 PM
.Grimace
Suspension & Brakes
Aug 10, 2006 09:56 PM
shiroitenshi
May 24, 2006 09:13 AM
thork
Jun 10, 2005 10:13 PM
