smaller crank pulley on h22/ef
just wondering if there is any aftermarket crank pulley that is smaller than the factory one? my h22 is in a ef and it's slightly rubbing on the lower controlle radius rod. thank you.
you probably only have an alternator on it right(no power steering or ac) if so Im pretty sure king motorsports can shave/grind off the extra parts on the outside of the pulley and re-balance it, call em up
yea that is all I have, but that's not what's hitting, not the extra stuff, only the complete lower pulley. I need a smaller one. like one inch smaller. HELP
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jayjay »</TD></TR><TR><TD CLASS="quote">I'm thinking your car is to low.</TD></TR></TABLE>
nope, stock hight now
What you need sir, is not a smaller pulley but a set of traction bars. On the aftermarket bars you can mount the radius rod on the bottom of the lca instead of the top providing mucho clearance. I used the explicitspeed bar. Great quality and was produced specifically for ef chassis with h22's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thevtecnician »</TD></TR><TR><TD CLASS="quote">What you need sir, is not a smaller pulley but a set of traction bars. On the aftermarket bars you can mount the radius rod on the bottom of the lca instead of the top providing mucho clearance. I used the explicitspeed bar. Great quality and was produced specifically for ef chassis with h22's</TD></TR></TABLE>
yes, i have the explicit speed as well and although the crank pulley and radius rod dont touch they are still quite close!
