lower ball joint castle nut
Old Apr 9, 2008 | 08:12 AM
pprowler6's Avatar
Default lower ball joint castle nut
while replacing my axles i managed to screw up the threads on on one of the castle nuts on my my lower ***** joints. I didnt think much of it becasue i had an extra nut from honda lying around. The only problem is it didnt fit becasue last year i ordered replacement no name ball joints online and they use a differnt size castle nut. Any ideas of what i should do or where i can find somewhere that sells castle nuts? Thanks
Old Apr 9, 2008 | 08:30 AM
Eddiebx's Avatar
my best suggestion is to hit up an autoparts store and bring your old castle nut. they sell various sized ones, so u might be able to find a mating one.
Old Apr 9, 2008 | 08:37 AM
Hawkze_2.3's Avatar
Default Re: (Eddiebx)
Yeah, check any auto parts store or McMaster-Carr should have it for sure as long as you know the thread size & pitch.
Old Apr 9, 2008 | 10:58 AM
pprowler6's Avatar
Default Re: (Hawkze_2.3)
any way of figuring out thread size and pitch???? would like pepboys or autozone have castle nuts?
Old Apr 9, 2008 | 11:08 AM
Hawkze_2.3's Avatar
Default Re: (pprowler6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pprowler6 &raquo;</TD></TR><TR><TD CLASS="quote">any way of figuring out thread size and pitch???? would like pepboys or autozone have castle nuts?</TD></TR></TABLE>
Yeah if you don't have any kind of thread gauges, you can go to Home Depot/Lowes and use those little sample boards they have to figure out thread size. That's what I always used to do
Pepboys/Autozone should definitely have some castle nuts.
Old Apr 9, 2008 | 11:12 AM
pprowler6's Avatar
sweet thanks Hawkze always can count on you for a thorough/good answer
Old Apr 9, 2008 | 12:24 PM
bluedlude's Avatar
a pitch gauge is another cheap invaluable tool.
Old Apr 14, 2008 | 09:01 PM
pprowler6's Avatar
Default Re: (bluedlude)
ok well the castle nut is 14 x 1.5mm any idea on where i can find one... ive checked mcmaster carr and the local honda dealer
Old Apr 14, 2008 | 09:16 PM
Hawkze_2.3's Avatar
Found one! $3
http://www.amazon.com/M14-1-5-...r=1-3
Old Apr 15, 2008 | 07:16 AM
pprowler6's Avatar
hahah sweeet thanks i can finally get this thing back on the road
Old Apr 15, 2008 | 02:28 PM
lude98SH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">
Pepboys/Autozone should definitely have some castle nuts. </TD></TR></TABLE>
I usually look in the helms or if the pitch isnt listed i get my tap and die set out and see what works.
Old Apr 15, 2008 | 02:53 PM
vinuneuro's Avatar
Napa and stores like carquest have parts like this readily available. No need to order online.
EnjoyTheRideDC2
Suspension & Brakes
11
Dec 11, 2006 10:11 PM
EnjoyTheRideDC2
Nov 7, 2006 12:09 PM
PINKS
17
Apr 17, 2006 06:55 PM
rasinhell
10
Feb 14, 2005 06:21 AM
DOMKID
Mar 17, 2004 12:31 AM
