B series axles male or female half shaft into an Ek
I got a female and a male half shaft. The female half shaft is about 15 and half long, the male is about 16. I got 2 axles but none of them have a female side for the male half shaft to go into.
One of the axles are about 23 and a half long and the other is about 24. I have a b18c1 gsr motor with a b16a3 S21 tranny in a ek. So which one do i use?!?
forgot the pics
FEMALE half shaft
MALE half shaft
forgot the pics
FEMALE half shaft
MALE half shaft
You can use either.. You just have to Match the driver side axle with the shaft
89-93 b motor used the male half shaft
94-01 used the female half shaft..
You will just need to get the correct axle to match with the half...
i have a full set of 91 axles in my ek* .. (male shaft)
Hope that helps
Hope that helps
edmek4
Apr 9, 2008 01:56 PM
biassj
May 16, 2003 03:57 AM
