ID this part
Looks like a purge valve. Probably linked to your evap system or something. When the car's running, do those nipples there suck in air? They may need to be hooked up to vacuum going to your evap canister.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackoutVTi »</TD></TR><TR><TD CLASS="quote">Looks like a purge valve. Probably linked to your evap system or something. When the car's running, do those nipples there suck in air? They may need to be hooked up to vacuum going to your evap canister.</TD></TR></TABLE>
i just checked the nipples if they sucked in air and its a negative. im pretty sure that it is what you guys are saying it is but i am wondering why its just hanging there. i will find out what is up and let you guys know what i find out.
all that is my afriend a a purge valve. its a vacuum switching valve that tells your canister when to release fuel vapors. the ecu controls that valve. you dont need it. just make sure that the vacuum source that came from is blocked off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6hatchboy »</TD></TR><TR><TD CLASS="quote">EVAP purge valve solenoid ftw
yup
</TD></TR></TABLE>yup
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6hatchboy »</TD></TR><TR><TD CLASS="quote">EVAP purge valve solenoid ftw </TD></TR></TABLE>
and you dont need it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egSLEEPER »</TD></TR><TR><TD CLASS="quote">and you dont need it </TD></TR></TABLE>
Yes you do. He lives in California.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supereg2 »</TD></TR><TR><TD CLASS="quote">thanks for id'ing the part but will this affect my car from passing smog?</TD></TR></TABLE>
Yes it will.
Also, if you just take it out, the vacuum leak will cause an inconvenient fluctuation in idle. Just spent some dough when I needed to replace the purge solenoid to pass smog.
Find a nice place to tuck it away if you don't need to fix/reconnect it to anything.
FYI, that little cap on the hose is a tedious, fragile little bastard part, with a tiny little diaphragm inside it. Take care of it, or you'll be paying a hefty price (for it's size) for a replacement. Hate those things.
Yes it will.
Yes it will.
FYI, that little cap on the hose is a tedious, fragile little bastard part, with a tiny little diaphragm inside it. Take care of it, or you'll be paying a hefty price (for it's size) for a replacement. Hate those things.</TD></TR></TABLE>
Okay. Sorry if you feel like
me but when you said that you spent money to replace the purge solenoid, were you talking about the purge "valve" or the solenoid is a whole different part?
I am panicking now because i am going to smog my car in a month and i don't know where to hook the purge valve at. can someone show me a diagram to how its supposed to be set up?
Yes it will.
me but when you said that you spent money to replace the purge solenoid, were you talking about the purge "valve" or the solenoid is a whole different part?I am panicking now because i am going to smog my car in a month and i don't know where to hook the purge valve at. can someone show me a diagram to how its supposed to be set up?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supereg2 »</TD></TR><TR><TD CLASS="quote">Okay. Sorry if you feel like
I am panicking now because i am going to smog my car in a month and i don't know where to hook the purge valve at. can someone show me a diagram to how its supposed to be set up? </TD></TR></TABLE>
Nah, I wasn't knocking on you, I was knocking on the guy who said you didn't need it. Don't worry, you have the part, and hopefully it's working. Now all you gotta do is get it in the right place. Don't trip man, I just don't want you going in unprepared. Hope you pass smog dude.
me but when you said that you spent money to replace the purge solenoid, were you talking about the purge "valve" or the solenoid is a whole different part?I am panicking now because i am going to smog my car in a month and i don't know where to hook the purge valve at. can someone show me a diagram to how its supposed to be set up? </TD></TR></TABLE>
slowpokecivic
20
Apr 29, 2006 12:41 PM
