99 si cel ?
Old Apr 8, 2008 | 10:08 PM
DOHC4banger's Avatar
Default 99 si cel ?
everytime i attempt the paper clip trick in the 2 pin connector clip
the cel just keeps blinking and doesnt stop???
Old Apr 8, 2008 | 10:15 PM
BlueIntegraBoy's Avatar
Default Re: 99 si cel ? (DOHC4banger)
Maybe you got a CEL for the primary O2 sensor.
Old Apr 8, 2008 | 10:16 PM
Default Re: 99 si cel ? (BlueIntegraBoy)
would that cause my car to die
Old Apr 8, 2008 | 10:19 PM
Not necessarily
Old Apr 8, 2008 | 10:22 PM
well my car keeps dieing and not wanting ot keep the battery charged so i have to jump the car to get it started but after im driving for like a minute or 2 everything starts to shut down, cd player, all my gauges aint working, then the engine starts to bog out and i have to keep revving to keep it alive
what else could i use beside paper clip or what am i doing wrong
Modified by DOHC4banger at 8:30 AM 4/9/2008
Old Apr 8, 2008 | 10:30 PM
Paper clip works best. You definitely have a CEL when your car is running?
Old Apr 9, 2008 | 07:23 AM
yes the cel comes on while im driving but wont throw me a code
ive got a brand new battery and the battery fuse isnt blown but when i take it off and put it back on the car will start??
Modified by DOHC4banger at 8:43 AM 4/9/2008
Modified by DOHC4banger at 8:58 AM 4/9/2008
Old Apr 9, 2008 | 07:43 AM
anyone got an idea?
Old Apr 9, 2008 | 07:56 AM
lsjon's Avatar
are the battery terminals all crudded up? loose terminals? check your grounds. check for any blown fuses. Any recent electrical items touched in your car, such as wireing? test alternator?
Old Apr 9, 2008 | 07:57 AM
lsjon's Avatar
lights blinking, and items shutting off, and new battery drain usually points towards alternator. try to gimp it to advance auto, or some local shop to have them run a alt test.
Old Apr 9, 2008 | 07:59 AM
Default Re: (lsjon)
ok will do
Old Apr 9, 2008 | 08:07 AM
pdiggitydogg's Avatar
You realize the cel will blink forever, as it runs in a cycle. You stop counting when there is a pause.
Sounds like you also have a loose connection at the battery or alt. That OR its failing.
Dont keep jumping the car - you have a serious drain, it sounds, so I would disconnect the neg cable each time you park instead.
Then run a draw test until you find the source
Old Apr 9, 2008 | 08:35 AM
Default Re: (pdiggitydogg)
there is no crud on the battery, i checked the grounds, i only jumped the car once so i can get it home, and im going to take it to a local shop and have it tested
and im not sure how to run this draw test
Modified by DOHC4banger at 9:53 AM 4/9/2008
Old Apr 9, 2008 | 11:51 AM
Default Re: (DOHC4banger)
its now throwing code 3 which is map sensor
would that cause all these problems?
Yell0w
Honda Civic (2001 - 2005)
Nov 16, 2009 10:21 AM
sPcIaLkSeRiEs
Sep 14, 2009 06:32 AM
Si_Guy2000
Sep 4, 2009 11:05 AM
rs_sexy
Nov 13, 2006 01:34 PM
S2KILLA
Jul 28, 2005 08:26 AM
