Suspension & Brakes Theory, alignment, spring rates....
A headache shock install....
Old Apr 8, 2008 | 07:10 PM
NVturbo's Avatar
O.G. triple O.G.
Default A headache shock install....
This afternoon I decided to install some new Tokico HP (blue) shocks w/ eBay coilovers on my del Sol. The front went pretty smooth without any issues....until I started working on the rear units. Like usual the bolts holding the rear shocks break off at the head on both L & R side. What made it worst was one of the bolts that holds the drum assembly breaks off also. To make the long story short, I replaced the rear passenger trailer arm with a '93 Civic coupe. I realized that the e-brake cable was a bit tad longer and did not have the same end (near the hand e-brake). Now, when the e-brake is engaged, the rear passenger tire doesn't lock like it should. Could it be that I need to swap out the cable back to the del Sol unit? I'm freaking tired as a **** and I really don't want to mess with it until the weekend. Any suggestions would be appreciated.
jsucci
Jan 4, 2008 05:48 PM
4ghatch
Suspension & Brakes
May 27, 2007 07:56 PM
Rich93DS
Sep 17, 2005 11:35 AM
setupjdmeg2
Apr 26, 2005 05:23 AM
LM Del Sol
May 9, 2004 08:33 PM
