b16 tranny question.
Old Apr 8, 2008 | 06:34 PM
slo_ej8's Avatar
Default b16 tranny question.
i have a b16 tranny that has been opened by the case and there is white rubber stuff around where the case goes..
i think its the seal?
my question: is it ok to run the tranny like that in a car? or do i need to take it to a shop so they can reseal it?
i will try to get a picture..
Old Apr 8, 2008 | 06:41 PM
MR.johnson's Avatar
Default Re: b16 tranny question. (slo_ej8)
honda bond is your friend.
Old Apr 8, 2008 | 07:27 PM
slo_ej8's Avatar
Default Re: b16 tranny question. (MR.johnson)
bump!
Old Apr 8, 2008 | 08:04 PM
slo_ej8's Avatar
anyone know? just the case was taken off and put back on. does it need to be resealed? thanks
Old Apr 8, 2008 | 08:39 PM
slo_ej8's Avatar
Old Apr 8, 2008 | 10:13 PM
slo_ej8's Avatar
someone has to know this.
Old May 13, 2008 | 06:53 PM
MIsterE533's Avatar
yes lol, use honda bond when you put it back on. it helps make the seal between the two aluminum cases. it also makes sure you dont strip your case bolts. dont use it on the bell housing to the engine block though. bad idea...
Jivejames67119
Jul 29, 2007 01:25 PM
Project_99Hatchback
May 12, 2006 12:20 AM
StogyBuiltDA9
Dec 10, 2004 05:05 PM
