Coolant problem. (Searched)
I'm having some issues trying to find a coolant leak.
It's not coming from the top of the engine compartment, it's completely dry, around all of the hoses that I can visually see.
It seems to be coming from around the bottom of the trannys bell housing....I'm assuming above the housing, but I can't tell.
The weird thing is, that it doesn't really drip/leak unless I push the engine a little hard. And when I meen hard, I meen like gunning it to get in front of someone.
I cleaned the engine compartment, and pressure washed the under belly of the engine/tranny, and I can barley see a small drip of anti. freeze, like I said located on the bottom of the tranny, but it sucking my reserve dry about every other day or so.
Any ideas?
Thanks....
Any ideas?
Thanks....
Thanks man,
I'm sorry, but I failed to give the following info. in the thread.
Idle boosts to 2000-2500 rpm while carnking back up, with engine still warm.
Idle maintains 1100 rpm and sometimes fluctuates to 1300-1400.
NO surge or pulse, indicating the fitv or aicv. Vacuums fine.
I'm also 100% sure that the thermostat is bad. Before I found the leak and realized it, she ran hot, one time, and the guage didn't register it over heating the engine.....
I found the leak.
Heater hose, right under the clamp. Thanks GOD.
The only way it jumped out at me, was one morning I had the defrost on high and upd the hood. It was a small pin hole leak, that I never would have found, unless it was 45 degrees outside with the heater on.
crazyhouse2011
63
Apr 27, 2014 11:31 AM
Ayashifx55
Dec 23, 2010 10:01 PM
xTimmyx
Aug 29, 2010 12:28 AM
