86' Teg has no pressure in clutch
Old Apr 8, 2008 | 05:30 PM
Guin-Teggy's Avatar
Default 86' Teg has no pressure in clutch
Ok, i just found out on here that the 1986-1989 integra's have a clutch cable, not hydrolic. I'm getting a 86 teg next week for 200, not in the best of condition but it runs fine, just no pressure in the clutch to go into gear is what the guy told me. What are my options on why it has no pressure? Even if its cable, could it still be the master or slave cylinder? I tried to get on G1teg.org but the administrator hasn't activated my account yet. Thanks in advanced for the help, much appreciated.
Old Apr 8, 2008 | 06:15 PM
gsilnc's Avatar
what do you mean by pressure? is it like just completely loose or you dont feel any give?
cause on my DA its cable and i dont really feel the pedal give way before i change gear but it works fine.
Old Apr 8, 2008 | 06:22 PM
Guin-Teggy's Avatar
Well the guy that im buying the teg from said he replaced the clutch and flywheel and pressure plate. But i was told by a few teg owners that the clutch release bearing could be bad or the fork of release lever could be cracked. he said that anything will press the cutch pedal to the floor and it will just stay there
Old Apr 8, 2008 | 08:06 PM
Frenshawas's Avatar
Default Re: 86' Teg has no pressure in clutch (Guin-Teggy)
the fork might be broke
Old Apr 8, 2008 | 08:39 PM
Guin-Teggy's Avatar
Well with a little bit of research done, i have narrowed it down to: release fork, clutch cable, or i need a new clutch kit(release bearing or spring might be [freak]ed)
Old Apr 9, 2008 | 04:17 PM
FM Chase's Avatar
bump
the master cylinder's dead, replace it n' u'll b fine. i had the same problem last week.
Old Apr 9, 2008 | 06:00 PM
Guin-Teggy's Avatar
but the clutch is cable, not hydrolic.. so it doesnt need the master cylinder..
Old Apr 17, 2008 | 10:05 AM
Frenshawas's Avatar
Default Re: (Guin-Teggy)
try to tighten the clucth line and if that doesnt work then pull the trans and look for any problems there
Gary Albano
Apr 8, 2013 02:56 PM
91sedanEf
Transmission & Drivetrain
Apr 2, 2010 12:38 PM
Remiss
Jun 2, 2009 05:09 PM
triniSiR
Jul 31, 2008 08:44 AM
infamousALLMTR
Jun 30, 2003 11:33 AM
