gsr head on my b16 block??
Old Apr 8, 2008 | 04:59 PM
ol'skool ferio's Avatar
Default gsr head on my b16 block??
hey whats up H-T... well my b16 head got striped where 1 of my spark plugs thread into ( the retard that had my car last must've done it). so my friend is selling me a full gsr head for real cheap. either way im getting it cuz i have to but my question is....will i make more power or will it be pretty much the same thing?
ive heard of poor mans type r's but never really read up on them to much. let me kno what you guys think.
all feed back is very thankful
Old Apr 8, 2008 | 05:09 PM
grog's Avatar
Default Re: gsr head on my b16 block?? (ol'skool ferio)
well the poor mans type R is the other way around, gsr block with a B16 head.
that is kind of an odd combo, I bet that not that many people have done this either.
you might actualy lose a little power with that.
The head is also taller so check your hood clearance and puchase a gsr header cause you will need it.
If I were you I would just locate a B16 head, theres something to be said for being able to get specific part for a motor as aposed to a frankenstein motor.
Modified by grog at 6:16 PM 4/8/2008
Old Apr 8, 2008 | 05:12 PM
Crx Jimmy's Avatar
Default Re: gsr head on my b16 block?? (grog)
the compression will go up quite a bit, im not sure how much . I know when you put a b16 head on a gsr block the compression goes down, So yours should go up quite a bit.
I would think you would get better performance if tuned properly, especially with the gsr cams.
Old Apr 8, 2008 | 05:29 PM
Default Re: gsr head on my b16 block?? (Crx Jimmy)
thanks guys and thats exactly what i was hoping for..for my compression to go up instead of down. im also gonna get my car tuned again. oh and i already have a gsr header
Old Apr 8, 2008 | 07:27 PM
rawkus's Avatar
From my understanding, compression goes up, flow goes down. Run it and let us know how it works.
Dan
Old Apr 8, 2008 | 07:35 PM
Default Re: gsr head on my b16 block?? (rawkus)
will do sir. ill have it done by this weekend hopefully.
Old Apr 8, 2008 | 07:48 PM
b18efsedan's Avatar
your compression is actually going to go down the gsr head is bigger (in cc's) than the b16 which will make the combustion chamber bigger and lowering you comp. ratio, you should get an ls block for next to nothing and throw the gsr head on that
Old Apr 8, 2008 | 09:11 PM
StylishDOHC's Avatar
Default Re: (b18efsedan)
Don't listen to the noobs....The GS-R head will work fine, the header will fit exactly the same..you will need a p72 ecu for proper function if you choose to keep the stock GS-R butterflies...The GS-R head will raise your compression from 10.2:1 compression to just above 10.4:1, and the flow difference is negligible...probably won't even notice the difference.
Old Apr 9, 2008 | 03:28 AM
thanks on the answers guys. i just cant wait till i get the head on friday. i also talked to a shop and they said it will also raise my compression but not alot. i guess we'll just have to wait and see
Old Apr 9, 2008 | 02:55 PM
b18efsedan's Avatar
Default Re: (StylishDOHC)
your an idiot thats absolutely wrong the gsr head has a BIGGER combustion chamber than the SMALLER b16 which would make your compression DROP to some where around 9.8 instead of the 10.4 cr a STOCK b16 puts out which will make your car slower i've seen it done my bone stock ls was quicker
Old Apr 9, 2008 | 03:10 PM
thehatchninja's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18efsedan &raquo;</TD></TR><TR><TD CLASS="quote">your an idiot thats absolutely wrong the gsr head has a BIGGER combustion chamber than the SMALLER b16 which would make your compression DROP to some where around 9.8 instead of the 10.4 cr a STOCK b16 puts out which will make your car slower i've seen it done my bone stock ls was quicker</TD></TR></TABLE>
EPIC FAIL!!!
slightly more compression, slightly more aggressive cams, with the IM secondaries you will probably gain some midrange. If you get it tuned you will make a little more power.
GSR head &gt; B16 head, but as stated before the differences are negligible.
Old Apr 9, 2008 | 05:45 PM
Default Re: (thehatchninja)
i dont kno but it sounds like your the idiot....and yup i plan on getting it tuned with a good set of cams
Old Apr 9, 2008 | 05:53 PM
Creator's Avatar
Default Re: (ol'skool ferio)
check for yourself
http://www.c-speedracing.com/h...c.php
Old Apr 9, 2008 | 07:05 PM
Default Re: (Creator)
<FONT SIZE="24"><FONT COLOR="red">B16A 42.70cc</FONT></FONT>
<FONT SIZE="24"><FONT COLOR="red">B18C1 41.60cc</FONT></FONT>
<FONT SIZE="24"><FONT COLOR="red">STOP POSTING INCORRECT INFORMATION, RETARD
</FONT></FONT>
Old Apr 10, 2008 | 03:20 AM
thanks on posting up that site for me man. it made me feel alot more comfortable with wanting to do this
Old Apr 15, 2008 | 09:51 AM
b18efsedan's Avatar
B16A 42.70cc
B18C1 41.60cc
i stand corrected noob ftl
Old Apr 15, 2008 | 11:24 PM
GreedyPT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18efsedan &raquo;</TD></TR><TR><TD CLASS="quote">your an idiot thats absolutely wrong the gsr head has a BIGGER combustion chamber than the SMALLER b16 which would make your compression DROP to some where around 9.8 instead of the 10.4 cr a STOCK b16 puts out which will make your car slower i've seen it done my bone stock ls was quicker</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18efsedan &raquo;</TD></TR><TR><TD CLASS="quote">B16A 42.70cc
B18C1 41.60cc
i stand corrected noob ftl</TD></TR></TABLE>
erm? 41.60cc is more then 42.70cc?
Old Apr 16, 2008 | 08:17 AM
kacivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreedyPT &raquo;</TD></TR><TR><TD CLASS="quote">
erm? 41.60cc is more then 42.70cc?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18efsedan &raquo;</TD></TR><TR><TD CLASS="quote">i stand corrected noob ftl</TD></TR></TABLE>
i think he acknowledged he was wrong...
Old Apr 16, 2008 | 08:56 AM
abnaasefmb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thehatchninja &raquo;</TD></TR><TR><TD CLASS="quote">
EPIC FAIL!!!
GSR head &gt; B16 head, but as stated before the differences are negligible. </TD></TR></TABLE>
lol
graveltravel2
Jul 25, 2009 07:58 PM
sick93sol
Apr 11, 2009 07:18 AM
hondachris1994
Sep 6, 2006 06:23 PM
FROSTDC2
Oct 27, 2005 09:40 PM
maxheat
24
Feb 26, 2005 12:36 PM
