Are fog lights prewired?
Old Apr 8, 2008 | 03:52 PM
92SR4WS's Avatar
Default Are fog lights prewired?
Hi,
I have a 1992 SR4WS and im installing fog lights. I have heard that my car is prewired for fogs is this true?
Thanks
-Greg
Old Apr 8, 2008 | 06:25 PM
92SR4WS's Avatar
Default Re: Are fog lights prewired? Please help!!(92SR4WS)
okay so ive been out working on my car and im like 90% sure that it is prewired. what im doing now is trying to find where the harness is for the switch to go? does anyone know? anyone that has put fogs in a 92 would know. please help!
Old Apr 8, 2008 | 07:11 PM
Giant_Bean's Avatar
Default Re: Are fog lights prewired? Please help!!(92SR4WS) (92SR4WS)
http://www.hondaautomotivepart....html
Old Apr 8, 2008 | 08:28 PM
92SR4WS's Avatar
Default Re: Are fog lights prewired? Please help!!(92SR4WS) (Giant_Bean)
thats for 94-95, 92 -93 have different console and the switch is in a different spot does anyone with experience of doing this foglights install know?
Old Apr 9, 2008 | 04:36 AM
AmauryR's Avatar
From experience doing the oem fogs on my other hondas, as well as my mom's bf's 07 civic. Usually the fogs are pre-wired ONLY at a certain point. meaning, theres connectors (usually taped off with blue tape) that are for fogs/accessories. I know on my lude, I saw blue taped off connectors up front (fogs) that go into the main harness. The foglight subharness plugs in under the dash, then runs out to wherever the switch location is. Even though the foglight switch is in a different location, the idea is the same. The switch harness-side of it plugs up under the dash into a brown connector (taped to the main harness with blue tape). Same thing with my mom's bf's civic, he got the "jdm" fogs and I followed the usdm instructions for the most part (main difference is the "jdm" uses a push switch, usdm fogs actually replace the light switch stalk). Front-harness connectors were there (taped off in blue), found the interior connections (taped off in blue). Just plugged it all up and routed the wires. hth.
Old Apr 9, 2008 | 10:38 AM
23series's Avatar
If the connector your looking for is for the switch, it will be in the dash behind the driver-side tweeter. It is not visable, you'll be able to see were there is a buch of wires come through a whole in the back of the dash. You will need to reach in there and dig for the plug(hopefully you have small hands) that plug location is for the tweeter cover mounted switch(very had to find). Hopefully this helped and good luck getting to the plug.
Old Apr 9, 2008 | 03:54 PM
94vtirozguy's Avatar
yes most of the wiring is already in the car.
all you need is:
- relay
- subharness
- fog lights
- switch
Old Apr 9, 2008 | 09:45 PM
92SR4WS's Avatar
Default Re: (94vtirozguy)
okay so ive found the switch, now ive heard i can just use a heated seat switch for my switch but it isnt even close to fitting... i guessing the sub harness conects to the switch and then i can plug the heated seat switch in to the other end of the sub harness?(if that made anysense to anyone...)where do i get a sub harness can i just makeone??? if so what do i need?
and where do i get the relay
Old Apr 10, 2008 | 07:56 AM
Giant_Bean's Avatar
Default Re: (92SR4WS)
I used a universal 4 pin fog light relay(I can get you a part # if needed), and a pigtail to fit on the relay. I then attached spade terminals and wired it up to the existing harness. For the switch I used a rocker switch( http://www.napaonline.com/NOLP...09999 ) and wired that up to the plug under the center console. The wiring diagrams that are in the instructions link I poster earlier were a big help.
Old Apr 10, 2008 | 05:07 PM
yes the harness connects the relay to the main harness under the steering column.
EJ8freek
Honda Civic (2006 - 2015)
Aug 6, 2012 07:17 PM
SupaMonkey
Sep 16, 2008 04:07 AM
07civicsi77
Apr 14, 2008 05:12 PM
BB1LOViN
Aug 29, 2007 07:41 PM
Ponch
Apr 15, 2003 07:15 AM
