Cel wont turn off
i take off the negative battery terminal, and remove the fuse to the ecu. but when i put everything back, i start the car up, the cel is still there. Is this supposed to happen? ive had other cars where the cel goes away for a while then comes back after a hundred miles or so.
thanks alot
thanks alot
There are some CEL's that will come on right away and some that will come on while driving. Check the CEL's and see what they are. Until you fix the problem, they wont go away.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ej Girl »</TD></TR><TR><TD CLASS="quote">There are some CEL's that will come on right away and some that will come on while driving. Check the CEL's and see what they are. Until you fix the problem, they wont go away.</TD></TR></TABLE>
Yeah, here's how to pull the CEL code from the ECU:
https://honda-tech.com/zerothread/1901557
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by forcefed22 »</TD></TR><TR><TD CLASS="quote">pulling the fuse and taking the battery terminal off doesn't fix the problem... the light is on for a reason so read the code and fix it</TD></TR></TABLE>
wow, maybe the 08's have some hope
