no idle, run w/ throttle open
so i just swapped on a new intake manifold and throttle body and now my car will not idle. however i can get it to run if as soon as i start it i hold the throttle open a little(around 2000rpm) but as soon as i let off it just dies.
the intake amnifold i am using is an edelbrock performerx and a professional products tb (typeR)
i also checked for codes and code 14 came up which i believe is the iacv.
now this is where things get tricky....
with the way i have it all setup, i had to bypass my fitv because the tb i am using doesnt use one.
could the idle problem be because i bypassed the fitv??
TIA!!
TIA!!
mgags7
Jan 30, 2025 08:58 AM
import-tooner
Jul 3, 2013 07:49 AM
