recommended crankshaft replacement for FI
Old Jul 10, 2002 | 07:22 PM
mntdewred's Avatar
Default recommended crankshaft replacement for FI
would it be necessary to replace my stock crankshaft (d16y8) for FI? I plan on putting eagle rods onto them, etc. etc.
its in good condition. i suppose i could get it cleaned and micropolished, but i just wanted to see what people thought.
anyone replace theirs? thanks
Old Jul 10, 2002 | 07:26 PM
ninesecrx's Avatar
Default Re: recommended crankshaft replacement for FI (mntdewred)
Run your stock crank....its good stuff.
Old Jul 10, 2002 | 07:28 PM
VaporTrail's Avatar
New User
stock is great, just make sure it's in good shape before you perform any work to it.
Old Jul 10, 2002 | 08:46 PM
ceemarun's Avatar
Default Re: recommended crankshaft replacement for FI (VaporTrail)
what are your plans for any future mods or how much you planning on boosting?
Old Jul 10, 2002 | 09:10 PM
int3gra's Avatar
Default Re: recommended crankshaft replacement for FI (ceemarun)
get it balanced, micropolished as well.
you could go all out and buy the light Eagle crank.
or u could knife-edge your existing one.........but these two are not really necessary.
if u need the eagle crank contact Rocket in my sig.
Old Jul 10, 2002 | 09:16 PM
2K_TEG's Avatar
Default Re: recommended crankshaft replacement for FI (int3gra)
The Eagle crank is not available yet. I do not think they plan on making one for the D series motor anyways. Before you rebuild a D series motor I would suggest you at least consider swapping in a B series motor.
Old Jul 10, 2002 | 09:29 PM
mntdewred's Avatar
Default Re: recommended crankshaft replacement for FI (2K_TEG)
rebuilding the whole thing to be bulletproof against high boost.
i've already set my sights on building the d16. i like a good challenge.
how would i be able to check the crank to see if its "up to par" for this application?
thanks for your suggestions
Old Jul 10, 2002 | 10:09 PM
2K_TEG's Avatar
Good luck man, i too am up for challenges. Get a Helm's manual...it explains all the different measurements to take to ensure the crank is in good physical shape. Of course look it over for cracks.
Tim_EG
Apr 14, 2014 12:38 PM
ef4dr
Mid-Atlantic (Sales)
Mar 16, 2009 06:33 AM
sour97
Sep 30, 2007 05:05 PM
rudebwoy
Jul 22, 2007 03:03 PM
crx378
Apr 22, 2005 04:13 PM
