itr wing and more for sale...question also about brakes on my itr.....
here is my for sale thread. mods delete if want. i wanted to get these out in the r forum.....rear cargo cover, perfect py itr wing, block off plate for 94-01 integras and morehttps://honda-tech.com/zerothread?id=2255202
my question is, has anyone ever had problems with their steering wheel vibrating really bad when you hit your brakes a little...amd it happens at any speed.
im by far a noob. i first, spent the the money at a local part store to get a hook up from a friend to get all four rotors turned. that fixed the problem for a little bit...
then the problem came back and was persistant. i replaced the front two rotors and put brand new brembo brake pads on the the front. i had all brake lines checked and what not. no bubbles, correct amount of fluid, blah blah.
needless to say, its doing it again. so im going to spend some money and buy spoon calipers and brand new brembo oem replacement front rotors.....
any ideas would be appreciative. thanks
Modified by JDM_FRONTIN at 3:19 PM 4/8/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steadysupreme »</TD></TR><TR><TD CLASS="quote">Is it making any noise from the brakes?</TD></TR></TABLE>
nope none at all....just shakes the steering wheel real bad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dsav4shawn »</TD></TR><TR><TD CLASS="quote">Could it be a tie rod end issue? Ball joints or bad hub? How many miles?
GL</TD></TR></TABLE>
dunno man....replaced the hubs on both sides also along with the race bearings.....
the car just hit 52k
i would check out your wheel bearings and every thing else like said above this is most likey causing your problem....otherwise it sounds like warped rotors but you said you replaced them already
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR.#1446 »</TD></TR><TR><TD CLASS="quote">i would check out your wheel bearings and every thing else like said above this is most likey causing your problem....otherwise it sounds like warped rotors but you said you replaced them already</TD></TR></TABLE>
hmmm ok im going to replace the tie rod and see if that helps. im almost to the point of everything being brand new oem ish under the whole front of my car
make sure your slides are moving as they should. i think it is a issue with your front rotors rather then anything else seeing that the issue when any when you cut the rotors and returned.. remove the rotors and make sure on the back side there is nothing on the hub rust. and the slides move freeely
it seems like you're progressing through parts rather quickly before finding the exact source of the problem. then again, i would have said to resurface/replace the front rotors and then look at the hubs and bearings which you've already replaced... esh. as far as the tie rod ends go, are the bushings bad? maybe somehow that nut that secures the tie rod end backed out somehow? i would also assume you've torqued down the lug nuts...?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jomama »</TD></TR><TR><TD CLASS="quote">it seems like you're progressing through parts rather quickly before finding the exact source of the problem. then again, i would have said to resurface/replace the front rotors and then look at the hubs and bearings which you've already replaced... esh. as far as the tie rod ends go, are the bushings bad? maybe somehow that nut that secures the tie rod end backed out somehow? i would also assume you've torqued down the lug nuts...?
lol ya i have a bad habit of just starting to replace everything lol. i feel more comfortable i guess. o ya they are lol...my number one pieve......ill check the tie rods
</TD></TR></TABLE>lol ya i have a bad habit of just starting to replace everything lol. i feel more comfortable i guess. o ya they are lol...my number one pieve......ill check the tie rods
thevtecnician
23
Aug 3, 2006 01:26 PM
