B16a2 map sensor wiring diagram needed,help...
Old Apr 8, 2008 | 01:50 AM
baulum's Avatar
Default B16a2 map sensor wiring diagram needed,help...
Hi,i've a honda b16a2 obd1 92-95 and is throwing a cel 3.I think there are some wiring issues and it is possible that the map sensor cel 3 is related to the bad wiring.Is there anyone who can post me a map sensor diagram,i.e from sensor to ecu plug.i need to know which colour wire goes to which pinouts.Thanks in advance.
Old Apr 8, 2008 | 02:56 AM
hondatuning1989's Avatar
Default Re: B16a2 map sensor wiring diagram needed,help... (baulum)
let me know if this helps at all this is the obd 2 a2
Modified by hondatuning1989 at 1:46 PM 4/8/2008
Old Apr 8, 2008 | 12:48 PM
Default Re: B16a2 map sensor wiring diagram needed,help... (hondatuning1989)
and this is out of the 92-95 civic manual
Old Apr 9, 2008 | 10:57 PM
baulum's Avatar
Actually i've this info but it is an obd2 and it seems different to my harness.Anyway thanks.I would like to know if there is an orange/ blue wire which is linked to map sensor?
Old Apr 9, 2008 | 10:58 PM
baulum's Avatar
my b16a2 is an obd1
Old Apr 9, 2008 | 11:00 PM
fmrprojects's Avatar
Default Re: (baulum)
is it a stock harness or custom harness. if stock, then you might have the map and tps plug switched around
Old Apr 9, 2008 | 11:32 PM
baulum's Avatar
its a stock wiring but there is one wire which seems different from diagram.I'll have locate to which pinouts where the difference is.
97EKCRVtec
Aug 18, 2009 11:36 AM
Del Sol on Steroids
Nov 22, 2006 12:50 PM
nick-vti
Aug 10, 2004 09:27 PM
Ski11z
May 10, 2004 12:57 PM
