removing&replacing wheel bearing
Old Apr 7, 2008 | 08:41 PM
anotherstar_noz's Avatar
Default removing&replacing wheel bearing
i have a 90 crx si and like everyone knows the wheel bearings go bad and i want to kno if anyone has pics and instructions on how to remve the bearing and replace with the new bearing its the passenger front......
Old Apr 8, 2008 | 04:59 AM
nwf_snake's Avatar
Default Re: removing&replacing wheel bearing (anotherstar_noz)
I have a Hub Tamer kit that makes it (relatively) easy. I also found I needed a bearing seperator to remove the outer race from the hub. I am sure others have rigged something up that works and is less expensive.
Old Apr 8, 2008 | 05:16 AM
zccr-xsi's Avatar
the wheels bearing has to be pressed out and back in.
Old Apr 8, 2008 | 11:56 AM
ArtyG's Avatar
https://honda-tech.com/zerothread?id=1567042
CRX/Civic FAQ, sahn!
MadVladCivic
23
Oct 13, 2014 10:46 AM
RacerTim
Sep 10, 2010 05:44 PM
petergriffen
Aug 11, 2006 08:44 PM
Bnjmn
Sep 20, 2005 03:43 PM
yung98gsr
Feb 18, 2005 09:28 AM
