Brake Fluid Leaking... Rear Drums the cause?
Old Apr 7, 2008 | 08:37 PM
slacks's Avatar
Default Brake Fluid Leaking... Rear Drums the cause?
A friend of mine suggested to me that there could be fluid leaking from the rear drums and that 92-95 civics developed that kind of problem.
I'm going to check the calipers for tears this weekend but is there anything in specific about the drums to look at?
They also tend to not hold evenly when the parking brake is up.
Old Apr 7, 2008 | 08:39 PM
crazyguy's Avatar
Default Re: Brake Fluid Leaking... Rear Drums the cause? (slacks)
check the brake hoses for tear and wear. check the brake bleeders..check brake hoses goes from chassis to calipers and rear drum..if they are loose
Old Apr 7, 2008 | 08:40 PM
Tzarinque's Avatar
Well do you see fluid on your drums? Your going to check you calipers for tears huh? Yeah those metal things are flimsy as hell and tear like paper. Just change your rear drum pads and be done with it
Old Apr 7, 2008 | 08:46 PM
bubblebrain's Avatar
Default Re: Brake Fluid Leaking... Rear Drums the cause? (Tzarinque)
what? rear drums but you're gonna check the calipers? weird, cause if i'm correct, there aren't calipers on a drum brake set-up. wheel cylinder sounds like the culprit...
Old Apr 7, 2008 | 08:47 PM
slacks's Avatar
hoses were the first things i checked
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy &raquo;</TD></TR><TR><TD CLASS="quote">check the brake bleeders..</TD></TR></TABLE>
check if they're just loose?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tzarinque &raquo;</TD></TR><TR><TD CLASS="quote">Your going to check you calipers for tears huh? Yeah those metal things are flimsy as hell and tear like paper. Just change your rear drum pads and be done with it</TD></TR></TABLE>
No..... the calipers have a rubber boot in them that can tear and leak fluid...
Old Apr 7, 2008 | 08:49 PM
slacks's Avatar
Default Re: Brake Fluid Leaking... Rear Drums the cause? (bubblebrain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bubblebrain &raquo;</TD></TR><TR><TD CLASS="quote">what? rear drums but you're gonna check the calipers? weird, cause if i'm correct, there aren't calipers on a drum brake set-up. wheel cylinder sounds like the culprit...</TD></TR></TABLE>
A friend of mine told me that rear drums on 92-95 civics tended to go bad, I don't remember the specifics so it seemed to be a good idea to at least check them. I was just wondering if someone else heard of this.
And YES i was going to check the calipers in case the rubber seals went bad and were torn or something wasn't bolted up right.
Old Apr 7, 2008 | 08:50 PM
yes the caliper has a boot, but that just protects the piston from contamination. the piston rides on a teflon seal.
Old Apr 7, 2008 | 08:51 PM
Former User's Avatar
Be sure to inspect the rear wheel cylinder, which is a common location for leaks:
Old Apr 7, 2008 | 08:52 PM
slacks's Avatar
Default Re: Brake Fluid Leaking... Rear Drums the cause? (RonJ@HT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RonJ@HT &raquo;</TD></TR><TR><TD CLASS="quote">Be sure to inspect the rear wheel cylinder, which is a common location for leaks:
[expletive] thank you! someone who knew what the hell they were talking about.
i appreciate it!
nycpatron
Sep 6, 2016 06:58 AM
Airman614
11
Aug 16, 2013 06:32 PM
sirjmj
Jul 14, 2008 10:06 PM
immajackuup
17
Jun 2, 2008 09:46 AM
89sicivic
Mar 2, 2006 10:01 AM
