CAR WONT STAR! clicks, the batt. drains??
Old Apr 7, 2008 | 07:08 PM
DCRbullet's Avatar
Default CAR WONT STAR! clicks, the batt. drains??
hey guys,i was doing a wire tuck and after hours of work and finishing everything i tried to start the car and it clicked and the battery died completely.... so i put some jumper cables and hooked it up to another car and it just clicks a lot from around the starter
please help me out, thanks for your time.
Old Apr 7, 2008 | 07:38 PM
shad0wslay3r's Avatar
Default Re: CAR WONT STAR! clicks, the batt. drains?? (DCRbullet)
Did you check the connections on the starter...?
Old Apr 7, 2008 | 07:48 PM
DCRbullet's Avatar
Default Re: CAR WONT STAR! clicks, the batt. drains?? (shad0wslay3r)
yuuuup. so would it be the battery even if directly connected to another running car with cables and it still didnt start? this kinda just came to mind.
Old Apr 7, 2008 | 08:43 PM
2ndchirp's Avatar
did you try a new battery.. yours might be bad.. or if you crossed some wires it culd have damaged the batttery... if it does the same clicking noise with a new battery you should check all the fuses that have to do with your car starting up like fuel injection...or anythin that has to do with spark ..etc..
Old Apr 7, 2008 | 08:58 PM
LSracing94's Avatar
Default Re: CAR WONT STAR! clicks, the batt. drains?? (2ndchirp)
dead battery..maybe youre grounding out somewhere after doing the tuck? check ur wiring
Old Apr 7, 2008 | 09:54 PM
calibur's Avatar
my buddy had the same problem... all he hear was the clicking sound. but his problem was his timing belt. not sure if that is your problem though. could be.. could also be your water pump.
Old Apr 8, 2008 | 07:50 AM
lotofIntegraty's Avatar
Default Re: (calibur)
it could be alot of things... it could be the
timing belt,
ur fuel lines may not be flowing
fuel pump relay
fuel pump,
fuel filter
oh yah da worst thing your gasket. i think the cylinders may be gettin wet inside i donno.. i had that problem wit my car... i went down the list till i got the problem fixed.. so anyone has other ideas to give em'?
Old Apr 8, 2008 | 08:17 AM
JDM-Riders's Avatar
Default Re: (lotofIntegraty)
I had a similar problem with my car and it was the dizzy.
Old Apr 8, 2008 | 08:51 AM
JDM.'s Avatar
Default Re: CAR WONT STAR! clicks, the batt. drains?? (LSracing94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSracing94 &raquo;</TD></TR><TR><TD CLASS="quote">dead battery..maybe youre grounding out somewhere after doing the tuck? check ur wiring</TD></TR></TABLE>
I agree a wire could be grounding out somewhere, or a faulty wire somewhere along the harness.
egtony
May 18, 2009 09:58 AM
euroborn1
21
Aug 15, 2008 11:46 AM
Legendaryyaj
Mar 8, 2007 01:41 PM
Senbonzakura
Feb 13, 2005 01:19 PM
TurboTypeR98
May 27, 2002 08:26 PM
