Car won't start on first try - takes a few tries
Old Apr 7, 2008 | 05:44 PM
b18cEK's Avatar
Default Car won't start on first try - takes a few tries
Hi, I just bought a new car and it takes a few times of turning the key before it actually starts. It doesn't even crank until I turn the key for the 4th time or so and then it actually starts up on the first time it cranks.
Could it be the ignition switch, low fuel pressure?
Everything is stock on this '99 SI.
Any input is appreciated.
Thanks!
Modified by b18cEK at 11:53 PM 4/7/2008
Old Apr 7, 2008 | 05:49 PM
DCSportEJ1Civic's Avatar
Default Re: Car won't start on first try - takes a few tries (b18cEK)
if it doesnt crank its something with your starter or ignition switch. i would guess a bad starter or a bad connection somewhere.
mechanix619's Avatar
It could be so many things. Can you get the accessories to work? Check the alt, battery, starter, and ignition.
Old Apr 7, 2008 | 05:51 PM
Blzdeep's Avatar
Default Re: Car won't start on first try - takes a few tries (DCSportEJ1Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCSportEJ1Civic &raquo;</TD></TR><TR><TD CLASS="quote">if it doesnt crank its something with your starter or ignition switch. i would guess a bad starter or a bad connection somewhere.</TD></TR></TABLE>
ya, i'd start here before you tear into everything else it "could" be.
Old Apr 7, 2008 | 06:02 PM
b18cEK's Avatar
Default Re: Car won't start on first try - takes a few tries (Blzdeep)
What about main relay???
Old Apr 7, 2008 | 06:04 PM
b18cEK's Avatar
Default Re: Car won't start on first try - takes a few tries (mechanix619)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mechanix619 &raquo;</TD></TR><TR><TD CLASS="quote">It could be so many things. Can you get the accessories to work? Check the alt, battery, starter, and ignition.</TD></TR></TABLE>
Accessories work. Definitely not the battery.
I was thinking ignition switch or main relay?
Old Apr 7, 2008 | 06:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cEK &raquo;</TD></TR><TR><TD CLASS="quote">
When you turn the key to ACC can you hear the Main Relay click, can you hear the fuel pump prime? If no to either then it's Main Relay or fuel pump.
Old Apr 7, 2008 | 07:33 PM
Mugen112's Avatar
Does it not crank at all until the 4rth try? Sounds like an ignition problem. A main relay would still allow it to crank. It may be a dead spot in the starter as well, but it would only do this sometimes (not all the time). GL.
Old Apr 7, 2008 | 07:43 PM
b18cEK's Avatar
Default Re: (Mugen112)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen112 &raquo;</TD></TR><TR><TD CLASS="quote">Does it not crank at all until the 4rth try? Sounds like an ignition problem. A main relay would still allow it to crank. It may be a dead spot in the starter as well, but it would only do this sometimes (not all the time). GL.</TD></TR></TABLE>
it depends... sometimes it's the second time and sometimes it could be the 7th time...
ignition switch?
Old Apr 7, 2008 | 07:44 PM
jasonjdm's Avatar
let your fuel pump prime
jasonjdm's Avatar
or check grounds and main relay
Old Apr 7, 2008 | 07:47 PM
b18cEK's Avatar
Default Re: Car won't start on first try - takes a few tries (jasonjdm)
I hear the fuel pump click everytime, so I do not think it's the main relay or fuel pump...
Old Apr 7, 2008 | 07:51 PM
NoBrows's Avatar
can you hear the starter turning? if you can check the coil ive seen this problem many times
Old Apr 7, 2008 | 07:53 PM
b18cEK's Avatar
Default Re: (NoBrows)
you cannot hear the starter turning
Old Apr 7, 2008 | 07:58 PM
NoBrows's Avatar
Default Re: (b18cEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cEK &raquo;</TD></TR><TR><TD CLASS="quote">you cannot hear the starter turning</TD></TR></TABLE>
then sounds like you have a bad starter next time it doesnt crank hit it with a hammer and see if it dont crank right up
Old Apr 7, 2008 | 08:08 PM
b18cEK's Avatar
the starter doesn't make any noise at all though? the starter doesnt even click?
but then on maybe the 4th attempt to start it it cranks over fine and starts up!
Old Apr 7, 2008 | 08:09 PM
NoBrows's Avatar
yeah i bet the starter contacts are all f'ed up
Old Apr 7, 2008 | 08:11 PM
b18cEK's Avatar
what do you mean by the contacts being messed up? corroded? or just not connected properly? Would that mean i need a new starter?
Old Apr 7, 2008 | 08:22 PM
NoBrows's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cEK &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean by the contacts being messed up? corroded? or just not connected properly? Would that mean i need a new starter?</TD></TR></TABLE>
starter contacts lose their conductivity and stick , starters go bad so just go by a new one that should fix your problem try the hammer thing that will help you confirm the problem
Old Apr 7, 2008 | 10:27 PM
Mugen112's Avatar
Could be a bad starter (dead spot) or your ignition switch is bad.
Old Apr 9, 2014 | 06:48 PM
asm383's Avatar
anybody resolve this problem im having the same thing and ive replaced new starter alternator battery cleans all leads terminals but if I jump it start up right away
Old Apr 9, 2014 | 07:14 PM
Former User's Avatar
Ancient thread closed. Please create your own thread.
rdzona
Aug 28, 2014 10:13 PM
mongo592
Acura TL, RL & ZDX
Nov 9, 2007 06:10 AM
reelhybrid
Feb 1, 2007 03:05 PM
sohctodohc
Oct 18, 2006 09:08 PM
turboxsi
Jan 29, 2004 01:33 PM
