Possible radio interfearence from HID?
Old Apr 7, 2008 | 04:21 PM
tsouyporta's Avatar
Default Possible radio interfearence from HID?
I installed some HID's about a year ago on my 00 accord coupe. They're phillips and i bought them from a guy on the HT marketplace. alls good untill recently when i have the HID's running, there's faint static on my radio stations...stock 6-disc in dash unit and everything...? any help guys?
Old Apr 7, 2008 | 04:22 PM
TheMuffinMan's Avatar
He knows where you live!
Do you have the wiring shielded? Might be worth while to insulate the ballasts and wiring.
Old Apr 7, 2008 | 04:26 PM
tsouyporta's Avatar
Default Re: (TheMuffinMan)
What do you recomend using to insulate? i have the ballasts mounted just bellow each strut mount...any suggestions?
Old Apr 7, 2008 | 04:38 PM
http://www.sertim.com/en_zipper/index.php
Something like that probably wanna search around and see what you can find, you can probably get away with just doing the antenna wire with that.
Old Apr 7, 2008 | 04:45 PM
tsouyporta's Avatar
I'll try that out, thanks a lot
Old Apr 7, 2008 | 04:48 PM
Probably be worth it, it's possible your HIDs are hitting a frequency that's interrupting the radio.
Does it happen with CD's as well?
Old Apr 8, 2008 | 04:03 PM
tsouyporta's Avatar
nope, just the radio. Come to think of it that makes a lot of sense. Now mechanically it would be easier to sheild the HID wires, would i get the best results by doing that or should i go straight for the antiena wires?
Old Apr 8, 2008 | 04:06 PM
Yep if it's not messing with CD's I'd wager that's your problem
Either way would work, you just need to shield it. If the HID wires are easier (I'm sure they are) I'd just wrap those up and you should be good.
VTEC_PRODUCTION
Jul 17, 2007 06:17 PM
OceanStateTuning
Acura TSX
Apr 14, 2007 10:27 AM
ejmatzell
Apr 16, 2006 10:08 PM
SSBP DC2
Feb 18, 2003 09:15 PM
