humming sound coming out from cam gear
Recently the head was repaired i had a blown head gasket. Car not heating up or anything. I still feel hoses hard until thermostat opens..which is usually when fans turn on.
After work was done i noticed humming sound coming from timing belt area. I took of the t. cover to hear better where sound was coming from. I noticed the noise was coming from the cam gear. I checked my timing belt and feels kinda tight. Kept on checking and im hearing wierd thunt noise also but dont know if its the water pump or tensioner.
Water pump is a year old as well as the tensioner.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_tuned »</TD></TR><TR><TD CLASS="quote"> I checked my timing belt and feels kinda tight. </TD></TR></TABLE>
Fix that first....
Fix that first....
Define tight? Like you can't flex the belt at all? It can have up to 3/4ths an inch of deflection. If it's too tight, it can cause premature bearing failure in the water pump and such...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blk92_d16 »</TD></TR><TR><TD CLASS="quote">Define tight? Like you can't flex the belt at all? It can have up to 3/4ths an inch of deflection. If it's too tight, it can cause premature bearing failure in the water pump and such...</TD></TR></TABLE>
maybe your right...**** i didnt know water pumps had bearings.
Good to know!
how about the cam?
Good to know!
how about the cam?
riceburners1
13
Jun 2, 2004 10:57 AM
-slow ej-
Feb 26, 2004 09:38 AM
