i just want to be 100% sure on this
Old Apr 7, 2008 | 08:54 AM
patrickd_21's Avatar
Default i just want to be 100% sure on this
I just swapped in an SI tranny. I have a turbo d16y8 and ive gone through 2 CX tranny's in about 3 months cause they dont hold the power (the dif demolished itself on the first one and second gear demolished itself on the second)...So i heard alot of people saying that the SI tranny's are stronger and there're obviously shorter so i picked one up.
Now me and my friend were arguing on the way proper way to fill up a d series tranny and how much to put in (we didnt have our manual on us)...so my quesiton is :
1. do you fill it from the spring loaded cap under the starter or from the side?
2. and how much oil goes in?
i wanna get this straight once and for all
Old Apr 7, 2008 | 08:57 AM
tsdenny's Avatar
Default Re: i just want to be 100% sure on this (patrickd_21)
you fill it from the side till a small bit leaks out
i think its about 1.75 quarts
Old Apr 7, 2008 | 08:59 AM
ke98248's Avatar
The Si/Ex trannys have steel shift forks and are stronger than the other civic transmissions -- yes. fill it up til it starts to pour back out.
Old Apr 7, 2008 | 09:06 AM
Default Re: i just want to be 100% sure on this (ke98248)
cool thanks for the help guys
Old Apr 7, 2008 | 09:16 AM
speedooo's Avatar
easier way is to pull the vss and pour it in through there
Old Apr 7, 2008 | 09:40 AM
stoopidfast's Avatar
X2
Old Apr 7, 2008 | 10:03 AM
Juan_Mitosis's Avatar
If you pour it thru the VSS, then remove the bolt through were u originally are supposed to pour it in through, and pour it in through the VSS hole until it leaks out through the side.
Old Apr 7, 2008 | 11:23 AM
blk92_d16's Avatar
When or how are you breaking the diffs/gears? At the track? 3rd/4th gear pulls on the hwy? It's probably not the fact they're CX trannys, it's the way it's driven in comboination with the extra power being spead through them. GL!
Old Apr 11, 2008 | 04:42 AM
Default Re: (blk92_d16)
at the track and on the highway....blew diff at the track and blew second on the highway when i started to get some wheel hop...its not my driving trust me lol. It just cant handle the power
Old Apr 11, 2008 | 05:54 AM
b18 hatch mike's Avatar
Default Re: i just want to be 100% sure on this (speedooo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedooo &raquo;</TD></TR><TR><TD CLASS="quote">easier way is to pull the vss and pour it in through there</TD></TR></TABLE>
RockinthEFhatch
16
Feb 22, 2006 10:43 PM
Honda Crx
25
Sep 20, 2005 10:08 AM
oxhernandez
Sep 4, 2005 09:54 PM
91hondacrx
Nov 29, 2003 09:13 AM
KoRE
13
Jun 17, 2002 04:01 PM
