Are Skunk2 pro1 good for a turbo set up on a B16 engine ?
Old Apr 7, 2008 | 08:27 AM
saviour250's Avatar
Default Are Skunk2 pro1 good for a turbo set up on a B16 engine ?
Does any one had expirence of Skunk2 pro1 cams on a turbo set up on a B16 engine ? boost will be in the range of 15-20 psi
Old Apr 7, 2008 | 08:36 AM
Turbo-charged's Avatar
Default Re: Are Skunk2 pro1 good for a turbo set up on a B16 engine ? (saviour250)
from my experience...the pro1's seem to pick up a good amount of mid range on a lower horsepower car, and hold the power for a bit higher of rpm.........havnt really seen huge overall gains until it was on a car with a bigger turbo, running high boost, and making a lot of power.
over all i really like the cams, but dont normally suggest them until its a car making a decent amount of power.
Old Apr 7, 2008 | 10:28 AM
JDogg's Avatar
Default Re: Are Skunk2 pro1 good for a turbo set up on a B16 engine ? (Turbo-charged)
pro1's dont work well in NA b16's... so no they wont work very good. the engine is too small
Old Apr 8, 2008 | 05:59 AM
saviour250's Avatar
Default Re: Are Skunk2 pro1 good for a turbo set up on a B16 engine ? (JDogg)
My setup it should be a good one good lowerd comp pistons, rods, sleeved, arp bolts, ive installeb a block gridle in a B16 ferrea valve train, turbo T3/4, big intercooler, a bigger throttle body plus many other things. So it sgould not be a bad setup
redline1320
May 11, 2011 01:09 PM
jo-jo123
Jul 8, 2009 11:39 AM
vtec4max
Jul 23, 2007 02:56 PM
uberhaulin
Mar 7, 2007 06:19 PM
L8NightDrifter
Nov 2, 2004 04:39 PM
