how do i order bearings??
Old Apr 6, 2008 | 08:51 PM
Midori Green's Avatar
Default how do i order bearings??
and no it isnt just call and ask for them its confusing involves colors of the old bearings and whatnot just wanted to know becuase i need new oem bearings for my allmotor build but i want itr bearings
Old Apr 6, 2008 | 09:00 PM
EG8R's Avatar
Default Re: how do i order bearings?? (Midori Green)
Order the bearings for your block. Match up the letter and number on the crank and rod and order the color it matches up with on the chart in the service manual. There will also be letters stamped on the block which indicates the block side of the crank bearings.
Old Apr 6, 2008 | 09:02 PM
Default Re: how do i order bearings?? (EG8R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG8R &raquo;</TD></TR><TR><TD CLASS="quote">Order the bearings for your block. Match up the letter and number on the crank and rod and order the color it matches up with on the chart in the service manual.</TD></TR></TABLE>
its a swap... so i have no service manual.. and the bearings i need are not the same as the block i am using
Old Apr 6, 2008 | 09:05 PM
EG8R's Avatar
Then get a service manual. Or find access to one.
So you are not using an ITR block, are the bearings that much different if at all compared to what came OEM in the block you are using?
Old Apr 6, 2008 | 09:08 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG8R &raquo;</TD></TR><TR><TD CLASS="quote">Then get a service manual. Or find access to one.
So you are not using an ITR block, are the bearings that much different if at all compared to what came OEM in the block you are using? </TD></TR></TABLE>
my block is a b20b block (2 layer design) therefore the bearings are not the same as vtec bearings (3 layer design) the size and fitment of all the b series bearings are universal on other b series blocks... you get me??
Old Apr 6, 2008 | 09:12 PM
EG8R's Avatar
I was not aware of that.
I know that Honda does not have any information on how thick each bearing is for each color. I've tried looking before. It would be quite expensive to order bearings of the same color and plastigauge them and find out they are not the right size... But that is a way to do it, but again, it might get expensive.
Old Apr 6, 2008 | 09:17 PM
EG8R's Avatar
I just found this.
https://honda-tech.com/zero...age=1
Old Apr 6, 2008 | 09:28 PM
thats the thing i find it confusing i dont understand the chart
Old Apr 6, 2008 | 09:37 PM
nytosc's Avatar
From: New York in the summer, South Carolina in the winter
http://www.evans-tuning.com/te....html
voila!
CPreston
Feb 17, 2011 10:06 AM
NAlover
Apr 1, 2006 07:37 PM
brokenojoke
Dec 22, 2005 09:25 AM
dt4life
Jul 30, 2004 06:24 PM
ubreak_ubuy
Apr 26, 2004 06:31 PM
