Civics been backfiring......
Old Apr 6, 2008 | 07:04 PM
fryman's Avatar
Default Civics been backfiring......
I recently put on a new pipe....I didn't change anything else just the exhaust pipe.And ever since I did my car has been backfiring.
It doesn't do it all the time,it just seems to do it like if i slowly rev to about 4000 rpms or so and then switch to the next gear it'll backfire.It doesn't seem to do it if I gun it though.I'm thinking maybe my filters dirty and I'm not getting enough air or maybe my timings a bit off...but it never did it with the stock exhaust pipe so I dont know.
Any ideas?
Old Apr 6, 2008 | 08:31 PM
TibTeg's Avatar
Default Re: Civics been backfiring...... (fryman)
what do u mean by "slowly rev to 4,000" like if u drive slow it backfires while ur giving it gas???? cuz if its just backfireing when ur foots not on the pedal or low rpm dont trip BUT if its the other way around...we got a problem
Old Apr 7, 2008 | 04:38 PM
fryman's Avatar
Default Re: Civics been backfiring...... (TibTeg)
Well I mean I don't floor it and then switch at 4000,I have the pedal about midway or so and then switch when it gets to 4000 and it'll backfire when i let off the gas to switch.But like I said it doesn't always happen,just like 3 times out of 5.
Old Apr 9, 2008 | 03:28 AM
TibTeg's Avatar
SO basically when the cars slowing itself down itll backfire every now and then...sound about right??? Just to b safe check the Air filter make shure its still good and clean & that ur getting good air flow to the engine cuz if the thottle body gets to much air at once itll choke causing the car 2 backfire which isnt good but most likely its nuthin to worry bout.
Old Apr 11, 2008 | 08:12 AM
fryman's Avatar
Yea I think the filters dirty.Ill get another one or clean this one.Thanks.
Old Apr 11, 2008 | 08:35 AM
tx_ej8_49's Avatar
Did you just change the muffler or the entire exhaust? I have a full cat-back with a magnaflow cat but without the resonator(bad idea) and sometimes when i drive normal but take it to 35-4500 rpms before i shift, it will pop/backfire between gears. Or if im at like 5 grand in 2nd-4th gear after gettng on gas i can tap the gas and get it to pop/backfire. I call it the gun shot....it makes babies cry and crackheads run.
Old Apr 12, 2008 | 12:58 PM
fryman's Avatar
Default Re: (tx_ej8_49)
I just changed the muffler.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tx_ej8_49 &raquo;</TD></TR><TR><TD CLASS="quote">I call it the gun shot....it makes babies cry and crackheads run.</TD></TR></TABLE>
LOL.
GSR15
May 18, 2013 01:20 AM
4drint3gr4
Oct 15, 2007 10:27 PM
pooMan
Jul 26, 2005 05:25 PM
tallblondkid
Sep 15, 2004 01:24 PM
