Need some help ASAP...New clutch now it will not engage.
Old Apr 6, 2008 | 06:29 PM
new_climber's Avatar
Default Need some help ASAP...New clutch now it will not engage.
I have done several searches but can't seem to find what I am looking for.
I put in a new stock cluch, new pressure plate, through out bearing and flywheel/pilot bearing..
It is still up on the jack stands but when I put it in gear, I can turn the axles?? I did attempt to start it and I am able to switch gears with out using any clutch at all??
Pls Help, what have I done wrong. I just seems like the tranny shaft is either not going into the clutch plate? Or I put it together wrong and it is disengaged all the time.
Old Apr 6, 2008 | 06:43 PM
97grnrs's Avatar
Default Re: Need some help ASAP...New clutch now it will not engage. (new_climber)
is trans bolted on tight? it goes into gears without clutch running ? or off? watch the release arm while u push pedal make sure it moving
Old Apr 6, 2008 | 07:20 PM
akylem's Avatar
its fine you should be able to move the wheels even if its in gear. loosen the cable all the way too.
Old Apr 7, 2008 | 01:34 PM
Default Re: (akylem)
Yea you are right...last night was not a very productive night. After pulling the tranny 3 times to double check the clutch install. I realized that you need some drag...meaning the tires need to installed and the car needs to be on the ground. I think it was OK all along... I feel like a real idiot......
Now I it doesn't seem like the driver side axle is going all the way back in. Should it be flush with the seal??? I have been banging it for about 2hrs but it seems like it is hitting and installed.
Thx for the help/advice
Old Apr 7, 2008 | 03:11 PM
97grnrs's Avatar
Default Re: (new_climber)
it wont be flush no. i small gap it will have
Old Apr 15, 2008 | 11:23 AM
420Ninja's Avatar
I did kinda the same thing when I was swapping from a auto to manual, put my nice stage 2 exeddy clutch in and heard a loud pop when I played with that release arm and then it didnt feel like the release bearing was moving, so i pulled the tranny out, double checked everything, put it back in, still the same. Pull it out and check everything again, then I ordered a new clutch and put that in. Then I decided to put some ***** into it when I pushed on the release arm and it moved perfectly fine.
So i ordered a new clutch and pulled my tranny out at least 6-7 times during this swap. And it probably whent together fine the first time. Oh well lesson learned i guess.
lopezchris21
25
Nov 19, 2023 08:24 PM
russianswty
Jul 20, 2006 11:34 AM
trianglegreg
Jun 10, 2006 12:02 PM
turbocivic0618
Oct 9, 2005 10:12 PM
DRKSol
Mar 29, 2005 08:31 AM
