1990 Accord Problem
Old Apr 6, 2008 | 05:01 PM
aerc07's Avatar
Default 1990 Accord Problem
My 1990 honda accord that is standard will not start, it won't even crank. the battery is good also the starter is fine, the headlights, dome lights and tail lights work fine, but the signal lights, and wipers don't work, and when i turn the ignition on none of the dash lights work, and i dont hear the fuel pump working. what could be the problem?
Old Apr 6, 2008 | 05:08 PM
afreeclimber's Avatar
Default Re: 1990 Accord Problem (aerc07)
Sounds like your ignition switch/circuit. Turning the key to start should send a 12v signal to the starter. Check if it's doing that.
Old Apr 7, 2008 | 12:52 PM
aerc07's Avatar
Default Re: 1990 Accord Problem (afreeclimber)
could the problem also be a bad main relay?
Old Apr 7, 2008 | 02:08 PM
KILLAB17VTEC's Avatar
Genetically Gay
try tighten up the battery it might be loose.i had this happen before.
grracing
Feb 10, 2019 01:51 PM
Sam.R
Feb 11, 2018 09:51 AM
jonathanraycamacho
Apr 25, 2007 06:23 PM
tsdenny
Jan 15, 2005 11:33 AM
