H22 Cranks
hi folks, is the open deck h22 crank any different from the closed deck h22 crank? I have a JDM closed deck block and I have a crank out of a open decked H22 block, are all the bearings and clearances the same with the newer and the older H22s?
92-97 = 50mm mains
some 98's made in 97 have 50mm mains
98-01 = 55mm mains
different bearing clearances for different main sizes. The rod size is the same on all years.
your closed deck block has 50mm mains. Measure the mains from your crank. If they are 55mm, you have to get another crank or get another block.
98-01 = 55mm mains
dreperformance
Jul 25, 2011 08:12 PM
thanks anyway tho
