cracked d16y7 manifold
i replaced my O2 sensot and i found that my manifold is cracked, i dont have any codes or CEL, i was thinking of welding it but i was afraid that my cat is jammed, how should i know that its still usefull?! does it have a code?
i think u have cranked/tightened o2 sensor too hard.
u can weld it back on.but a aftermarket or oem used exhaust manifold should not cost u too much. any d series header will fit.
Modified by crazyguy at 1:56 PM 4/6/2008
i have a d15b oem header, but it only have a place for 1 o2 sensor, i was thinking of welding the 2nd o2 sensor, but i was afraid it wont work
All the y7 manifolds crack when they get old, the heat cycles over time of expansion and contraction get the best of the cast iron and they crack. Usually right down the middle. All the oem manifolds can crack but its more common on y7's because of the cat being inside them. Its more heat and backpressure.
hybrid90
Apr 23, 2012 02:47 PM
