B-series VSS interchangeable?
Just bought a B16 cable transmission and it didn't come with the speed sensor. I researched and people mention that
-All cable B-series VSS are interchangeable even the Automatic transmission.
So a DA Integra VSS should work on my B16 transmission correct?
-Also found a post which a D-series SOHC VSS will also work on a B-series transmission.
Correct me if I'm worng.
Modified by FOMULA91 at 1:43 PM 4/6/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR CRX »</TD></TR><TR><TD CLASS="quote">i also heard that they are interchangeable except that you may need to cut one of the legs off on the vss. but i heard they all work the same.</TD></TR></TABLE>
Thanks for the info. Wanted to double check before purchasing one or used the D-series one.
I am running a cable speed sensor from a 1991 CRX SI with my JDM B16A transmission with no problems. I am going to change out the cable speed sensor to an electronic VSS soon. I have read that a 1992 civic 3dr SI VSS speed sensor will work with the B16A tranny also.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xalents23 »</TD></TR><TR><TD CLASS="quote">I am running a cable speed sensor from a 1991 CRX SI with my JDM B16A transmission with no problems. I am going to change out the cable speed sensor to an electronic VSS soon. I have read that a 1992 civic 3dr SI VSS speed sensor will work with the B16A tranny also.</TD></TR></TABLE>
OK cool, so the D-series cable VSS will work on the B-Series transmission.
Thanks for the info once again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOMULA91 »</TD></TR><TR><TD CLASS="quote">Anyone use the SOHC VSS on a B-series Transmission?</TD></TR></TABLE>
not running yet but it fit like a glove
axtran
Apr 6, 2006 05:06 PM
automatic, bseries, cable, crx, electronic, honda, interchangeable, motor, motors, parts, sensor, series, speed, transmission, vss
