knocking front right
hey guys, i have a problem, maybe someone can help me out with this.
i have been experiencing a knock and a kick in the steering wheel on right turns.
when i'm driving straight, and turn right to any degree, there will be a kicking and knocking from the front right wheel. the more extreme of a turn, the worst the kicking and knocking.
i have changed several times axles, new wheel bearing, new hub, new endlinks, new tie rods, my ball joints are fairly new. i have even dropped my transmission to inspect it. it turned out good. all my bolts are tight/torque to specs. i can tell you i havent gotten an alignment yet and my lower control arm bushings are crack.
ONLY RIGHT TURNS!
ONLY RIGHT TURNS!
ke98248
Oct 23, 2007 12:10 PM
