Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
What kind of gains can you expect from a K&N drop in filter?
Old Apr 5, 2008 | 09:19 PM
Yunque5's Avatar
Default What kind of gains can you expect from a K&N drop in filter?
So there are whispers of the PasswordJDM power chamber coming out for the si... I dont want to waste money on another intake so I was thinking about just dropping in a direct replacement filter from K&N. Is there any difference over the stock Filter?
Old Apr 5, 2008 | 09:21 PM
Rainy City's Avatar
Default Re: What kind of gains can you expect from a K&N drop in filter? (Yunque5)
Flows a lot better, better throttle response. 5hp can be expected.
Old Apr 5, 2008 | 09:25 PM
Yunque5's Avatar
Default Re: What kind of gains can you expect from a K&N drop in filter? (Rainy City)
So this is actually worth the $. 5hp and factory airbox=
Old Apr 6, 2008 | 12:24 AM
TRE_'s Avatar
Performance gains? None. Maybe a slight increase in MPG and engine noise but the main advantage is having a cleanable air element...., as opposed to something you have to replace every so often. I've had one in my FG2 for over a year, no complaints.
Be careful not to over-oil the filter though, the MAF sensor can be ruined pretty easily ...
Old Apr 6, 2008 | 12:36 AM
Nighthawk R18's Avatar
Default Re: What kind of gains can you expect from a K&N drop in filter? (TRE_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TRE_ &raquo;</TD></TR><TR><TD CLASS="quote">Performance gains? None. </TD></TR></TABLE>
yuup
its worth the money if your keeping the stock intake setup in the long run. but not if your changing to an aftermarket one in less than 6 months.
i had one on my fg1 for a while. loved it
Old Apr 6, 2008 | 01:00 AM
WhiteGSR95's Avatar
doubt you'll get any power, but you will get better throttle response
Old Apr 6, 2008 | 07:51 AM
2008fijibluesi's Avatar
I've had a K&N drop-in since my car was pretty much brand new. You can expect a better sound from your intake, and a little smoother acceleration. Don't expect any noticeable boosts in power, but the extended life of the filter (reusable/cleanable) definitely makes it worth the money if you don't want an aftermarket intake.
Old Apr 6, 2008 | 11:32 AM
B16aDasher's Avatar
more like 1 or 2 hp.
Old Apr 6, 2008 | 03:34 PM
juicek20z3's Avatar
* B A N N E D *
Default Re: (2008fijibluesi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2008fijibluesi &raquo;</TD></TR><TR><TD CLASS="quote">I've had a K&N drop-in since my car was pretty much brand new. You can expect a better sound from your intake, and a little smoother acceleration. Don't expect any noticeable boosts in power, but the extended life of the filter (reusable/cleanable) definitely makes it worth the money if you don't want an aftermarket intake.</TD></TR></TABLE>
yup, very very true, best way said
Old Apr 6, 2008 | 05:27 PM
-stiffler-'s Avatar
Be careful not to over-oil the filter though, the MAF sensor can be ruined pretty easily ...</TD></TR></TABLE>
i was thinking of putting K&N as well but i am
a little bit concerned,for i heard that the oil will
eventually do more harm than good.
they claim it doesn't filter that well and if you overdo
the oiling part,it will mess up your sensors.
Old Apr 6, 2008 | 07:41 PM
24boosted's Avatar
Default Re: What kind of gains can you expect from a K&N drop in filter? (-stiffler-)
On very lightweight wheels and fins cut out I did feel a change in throttle response and midrange. On stockers nada. Then I stopped Mickey-Mousing around with it and went turdbo.
Old Apr 7, 2008 | 04:46 AM
manydubs's Avatar
You will gain more dirt flowing into the engine which COULD cause a dirtier MAF sensor and dirtier engine oil...
They flow better but in my opinion less particles get past a paper filter.
Old Apr 7, 2008 | 04:55 AM
Default Re: What kind of gains can you expect from a K&N drop in filter? (manydubs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by manydubs &raquo;</TD></TR><TR><TD CLASS="quote">You will gain more dirt flowing into the engine which COULD cause a dirtier MAF sensor and dirtier engine oil...
They flow better but in my opinion less particles get past a paper filter.</TD></TR></TABLE>
Really?!
I definitely do not share that opinion.
moores55
Honda Motorcycles
12
Feb 26, 2007 02:55 PM
ilikeric3
Sep 21, 2006 09:52 PM
ItalynStylion
Sep 2, 2004 03:12 PM
T_Rex
May 24, 2003 11:59 AM
4doorB18Bcivic
Apr 15, 2003 04:04 PM
