EK Cluster In EG Issues
Old Apr 5, 2008 | 04:51 PM
hold your breath's Avatar
Default EK Cluster In EG Issues
I have a 95 D16a Eg
Ok, the problem is when I converted the Ek cluster into the Eg the speedometer dont work. I know, I know search. I did that a million times. Before I put the Ek cluster in, everything was working on the Eg cluster. Now when I put the Ek cluster in the speedometer dont work and now I have a check engine light for Vss. I checked the wires, vss, cluster, grounds, plug connectors, and fuses. They all are fine. . Because I put the vss in another civic and it works. I put the Ek cluster in another civic and it works. Everything on the Ek cluster works expect the speedo. I was wondering do I need a 96-00 speed sensor the whole thing that goes inside the transmission?
Old Apr 5, 2008 | 09:23 PM
Default Re: EK Cluster In EG Issues (hold your breath)
BUMP!!!!!!!!!!
Old Apr 5, 2008 | 11:33 PM
T Rick's Avatar
WHY!!! Then Put the eg cluster back in
upgrayedd
Aug 6, 2010 03:48 PM
MeanD
Mar 6, 2005 01:28 PM
wm5holla
Mar 6, 2003 06:01 AM
