NEED HELP B18C gsr is messed up.......
i have a 98 civic with a b18c swap and just last night on my way home i heard a clicking noise from my engin...and i thought it was my bumper rattaling again but i took taht off and seen if it still did it..and it did....it seems like its coming from my head maybe??? can some one help me and may point out somthing wrong??
OMFG 1 month of having the car and you already have engine damage? i would say it is either a bent valve, broken valve spring or most likely a spun rod bearing ... and the only way you could have done that is by over revving it that motor was a very solid motor when I installed it a 2 years ago ... i am sorry the car went to to bad hands i hope after you get it fixed you will treat her better then that .... and get rid of those Jim Fab torque mounts so the car doesn't shake like your mama's vibrator
got the car fixed...i didn't spin a rod bearing or bend a valve...i just needed a valve ajustment and the oil changed....and im gunna have to agree with steve on the jimfabs the ladys do like it
A.E Motoring
13
Apr 18, 2006 08:39 PM
