HELP! fuel pump kill switch!! which wire?
Old Apr 5, 2008 | 12:28 PM
MrXclusivE's Avatar
Default HELP! fuel pump kill switch!! which wire?
Which wire do I need to cut for the switch?
Its a 98 ek hatch.
In the link it says the yellow/green wire, but there's like 3 yellow/green wires there! which one?
http://causeforalarm.thecarthi....html
Modified by MrXclusivE at 1:39 PM 4/5/2008
Old Apr 5, 2008 | 12:32 PM
MrXclusivE's Avatar
Did I even need to remove the rear seat?
Maybe I could've just removed the plastic on the driver side door lining?
Old Apr 5, 2008 | 12:37 PM
MrXclusivE's Avatar
Another pic, right at the fuel pump:
Old Apr 5, 2008 | 12:55 PM
BEE1's Avatar
Default Re: (MrXclusivE)
pm FCM
Old Apr 5, 2008 | 02:30 PM
mechanix619's Avatar
Fuel pump kill switches are pretty worthless, especially if you splice right at the pump. Make things a little harder, do it right the first time and put a switch on the ECU or Main Relay; all the wires can be hidden behind the dash.
Old Apr 5, 2008 | 03:55 PM
3lo's Avatar
3lo
https://honda-tech.com/zerothread/2076997
all_motor
Feb 3, 2013 11:30 AM
fusion645
Audio / Security / Video
May 9, 2011 04:48 PM
98y8
May 5, 2010 12:06 PM
Civic Si Kid
May 17, 2009 12:26 PM
gelabee
Jun 8, 2003 10:45 AM
