just painted my fender pic inside
Old Apr 5, 2008 | 12:15 PM
immajackuup's Avatar
Default just painted my fender pic inside
well my paint came out fine but when i started to do the clear coat it look jack up and it feel really bumpy rough.
do i have to wet sand it down with 2k grit and then clay bar it?
after that polish by hand with what product?
Old Apr 5, 2008 | 02:13 PM
mztykal's Avatar
Default Re: just painted my fender pic inside (immajackuup)
You painted it with bedliner?
BTW you're gonna have to sand it all off and spray your clear wetter. Thats loads of dry spray and overspray.
Old Apr 5, 2008 | 05:39 PM
RoadRage212's Avatar
Is the clear you're spraying coming out of that rattle can?
Your fender is all jacked up. Sand that mess off and start over and use better materials. A two-stage 'rattle can' job will never work the way you want it to. It wasn't designed to work like that. You need to spray gloss enamel black and leave it alone if you can't do it any other way.
Otherwise, get a compressor, a decent air gun and good materials and do it the right way. Search this forum there is a good knowledge base on this subject.
Old Apr 6, 2008 | 12:29 PM
SneezinCD5's Avatar
Default Re: just painted my fender pic inside (mztykal)
WOW! That dosen't look very good . Sand it off and redo it. If your using a rattle can you can still lay the clear down nice. If the can has a nice fan tip, there shouldn't be a problem getting it to look wet. I would say 2 med coats followed by a full wet coat on your last coat.
Old Apr 6, 2008 | 01:47 PM
radeonboy's Avatar
no way anything is gonna make that better. stop and do it all over again.
Old Apr 7, 2008 | 03:03 AM
how close do i spray the can on the fender?
Old Apr 7, 2008 | 07:37 AM
goldex420's Avatar
4-6 in long even strokes over the whole thing
Old Apr 7, 2008 | 05:18 PM
95teg_ls's Avatar
like stated above the rattle can clear will not match at all, just take it to a body shop, probably around 300 or so for them to paint it, or if you have a compressor get a gun and spray it
Old Apr 8, 2008 | 07:57 PM
faf2zz's Avatar
what they said....
chingro
Paint and Body
Apr 30, 2008 06:30 PM
immajackuup
Paint and Body
28
Apr 12, 2008 06:11 AM
mcgee*
Jan 3, 2006 02:52 PM
Cheivic
Mar 31, 2003 09:05 AM
Mr.SpiLLz
Mar 21, 2003 12:47 PM
