Quick wiring question w/ pics
Old Apr 5, 2008 | 12:05 PM
SYNSEI's Avatar
Default Quick wiring question w/ pics
I bought this VTEC subharness. Great product but I have questions (I didnt get directions).
These 3 wires are at the end of my vtec subharness.
I've deducted that I should plug them into this second set of wires (on the left).
Here's what my ECU looks like with the OBD0 to OBD1 jumper harness.
What do I do with the end of the 2nd set of wires?
Do I need to de-pin the jumper harness?
Thanks in advance.
Old Apr 5, 2008 | 02:13 PM
SYNSEI's Avatar
Default Re: Quick wiring question w/ pics (SYNSEI)
Anyone?
Old Apr 5, 2008 | 03:52 PM
unified112's Avatar
Does the vtec subharness go straight from the vtec pressure switch/solenoid/knock sensor, all the way to the ecu? Thats how mine was made. You have to run the harness through the fire-wall, de-pin your factory harness, and plug in the 3 leads of your subharness.
De-pin: A4 for the vtec solenoid
De-pin: D3 for Knock Sensor (If equipped)
De-pin: D6 for Pressure Switch
Now, I wasnt using a jumper harness, just the oem one. So, im not sure weather it would be easier to depin the jumper, or the oem side. But, hope something I said helps. lol.
*Edit*
Those pin locations are for the OBD1 wiring harness, so.. maybe it would be easier to depin the jumper harness. *shrug*
Old Apr 5, 2008 | 04:19 PM
SYNSEI's Avatar
Default Re: (unified112)
Thanks for the reply!
Well I bought the subharness from NHswaps13203 and he didnt run the wires straight to the ecu. Instead, theres a break (where the connectors are) in the wire. I'm sure theres a good reason for it, I'm just dumb when it comes to wires. Since I'm using the jumper harness, I'll need to depin those slots eh?
leftcoast
Aug 9, 2007 08:51 PM
89D15CRXDX
12
Mar 22, 2007 04:40 AM
Ya wanna race
Jun 28, 2004 09:32 PM
ahc'monracing
Jun 8, 2004 06:06 PM
teg2000
Nov 6, 2003 03:29 PM
