97 EX Brakes on RT4WD wagon
Old Apr 5, 2008 | 10:55 AM
EJAYATE's Avatar
I Deliver
Default 97 EX Brakes on RT4WD wagon
I'm assuming that 97 ex calipers and rotors are a direct swap. I looked in the faq and couldn't find anything specific for wagons. I think they have the same knuckle as the ex/si, which makes me think It should bolt right up.
LMK if you think otherwise.
Old Apr 6, 2008 | 11:34 AM
EJAYATE's Avatar
I Deliver
Default Re: 97 EX Brakes on RT4WD wagon (EJAYATE)
Ok I was given the wrong pads at the store, which accounts for some of my problems.
With the rotor off I was able to get the caliper mounted fine, but with the rotor on the caliper does not make it all the way to the two mounting points. Is there a knuckle or adapter bracket that will allow me to use the larger diameter rotor and caliper.
notes: ROTORS are 10.3 in diameter and 21mm thick
CALIPERS are from a 97 civic ex
my best educated guess is to use the knuckles from a 97 civic ex as well as the upper control arm and ball joint, but I am not sure if these parts are interchangable with ef civics.
Old May 5, 2008 | 03:57 PM
ssdjoey1904's Avatar
any luck? i have a 89 and i wanted to swap ls front knuckes on there but not 100 percent they will work,anyone know for sure/>
EFinawesomeman
Feb 8, 2009 05:52 PM
Igarut5410
Suspension & Brakes
Oct 26, 2008 03:06 PM
EJAYATE
Apr 6, 2008 11:33 AM
Shaka01
Suspension & Brakes
Nov 16, 2005 02:04 PM
carracr625
Nov 29, 2004 12:58 PM
