Dashboard not working - Integra 1988
Old Apr 5, 2008 | 07:54 AM
RobertEndael's Avatar
Default Dashboard not working - Integra 1988
Hi, my dashboard stopped working a while ago and I was wondering what might be a solution to it. My RPM, Fuel Guage, and Temprature Guage, all don't work anymore but my MPH Guage still works. I heard that it might be a blown fuse but I don't know which ones to check. Never really could learn about cars very well.
If it is a blown fuse, is there some way someone might be able to put up a picture so that I might be able to find it easier?
Forgot to mention my brake lights still work only when I press down on the brake peddal, but when I turn on my headlights, the back lights don't come on like they should. Also the turn signals dont work anymore at all.
Old Apr 5, 2008 | 08:18 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Dashboard not working - Integra 1988 (RobertEndael)
Your speedometer is run by a cable from the transmission. So it is independent of your electric gauges. Check the fuses in the fuse box.
Old Apr 5, 2008 | 08:46 AM
Default Re: Dashboard not working - Integra 1988 (Dogginator)
Yeah, but which ones do I check, shoud I just replace all of them?
Old Apr 5, 2008 | 08:58 AM
Dogginator's Avatar
Daisy... Daisy...
The fuse box should have a fuse diagram. You can look at the fuses to see if they are bad. If one is blown do not replace it with a higher current (Amp) fuse.
Hopefully you can get some help because there are no many Gen 1 owners here.
Old Apr 7, 2008 | 11:59 PM
maxoutracer's Avatar
happen to me before, there's a fuse under the dash...
more help? http://www.g1teg.org
Old Apr 9, 2008 | 02:15 AM
Default Re: Dashboard not working - Integra 1988 (maxoutracer)
Ok I acutally got the fuse fixed, my brother actually told me to put in a higher fuse and it is actually working better and isn't being burnt up ever time I turn on the turn signal. I think the wiring might be messed up inside of it or something.
Old Apr 9, 2008 | 03:16 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RobertEndael &raquo;</TD></TR><TR><TD CLASS="quote">Ok I acutally got the fuse fixed, my brother actually told me to put in a higher fuse and it is actually working better and isn't being burnt up ever time I turn on the turn signal. I think the wiring might be messed up inside of it or something.</TD></TR></TABLE>
Fix the turn signal. Installing a higher amp fuse can cause wiring issues much greater than you currently have.
Old Apr 10, 2008 | 04:49 AM
Ok, thanks, I will get that done, my car is in the shop right now but once it's out I will put on a new turn signal. If anything, I might have them replace some of the wiring and stuff in it anyway because it really is all messed up.
jdmouttheass
Honda Civic (2006 - 2015)
Jan 24, 2011 12:22 AM
spurge
Mar 28, 2006 06:41 AM
d16z6hondacrx
Oct 17, 2005 04:36 PM
Bobby808
Apr 10, 2005 11:13 AM
Rhythm Racer
11
Jun 27, 2003 10:46 AM
