axles question.. couldn't find it on search
i've got a rhetorical question.. but its just to double check.. i have a 94 gsr and my cousin didn't put the axle on the passenger side in all the way.. would the car still start without the axle in it? there are tranny fluid everywhere as well... i know its kinda stupid but i am having problems starting up my car and i just gotta knock it down to the very last reason why it aint starting..
thanks in advance
thanks in advance
It would still start, the car just wouldn't move if the axle popped out. Check all your grounds make sure they are clean and making good contact.
yeah.. it wasn't that.. but i checked the ground and they are all good.. we got the car to start but it seems to have a weak spark.. and wen i press the throttle the car doesn't seem to respond? ? ? any reasons?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRSC01GS-R »</TD></TR><TR><TD CLASS="quote">u didnt get your map and tps plugs on backwards did u?</TD></TR></TABLE>
I've seen that about a dozen times.
Causes the car to bog and spurter at idle, then when you give it gas it usually dies out.
turns out the sensor on the top of the throttle wasn't good so we changed that and the motor was new so we had to crank it a couple more times and wallaa.. it started.. oh yeah its turboed too. i don't know if i mentioned that earlier.. but now its off to tuning... do you think i can drive the damn thing over there? once i start driving it slowly on the street, it leans out?
u sure? i heard that that was actually bad? but im heading over there ina bit.. so wish a brotha some luck.. i'll keep ya updated
alright so im back.. he wouldn't tune my car.. cause the timing is off by about three to two tooths.. so very BAD!!!,,, we'll set the timing and hope for the best..
by the way.. the car pulled like ****.. boost kicked in and everything but it feels like the car fell flat on its face.. could it be cause the timing is off too?
and it is also very hard to start the car.
im running 750 RC's .. but we found out wat was wrong with them.. it was the timing... now the car pulls wen boost kicks in instead of falling flat on its face... now its up to tuning and making it run perfect..
HndGoob
10
Aug 19, 2004 06:58 AM
