clutch dont feel right, please help!!!!
Old Apr 4, 2008 | 10:17 PM
1320king's Avatar
Default clutch dont feel right, please help!!!!
ok i just replaced my clutch and flywheel and when i started the car and pressed the clutch in and put it in gear and let the clutch out it starts to grab about 2" off the floor...idk it doesnt seem right to me, should it be like that? any info would be good thanks!!
Old Apr 4, 2008 | 10:35 PM
Johnny-Red's Avatar
Default Re: clutch dont feel right, please help!!!! (1320king)
If its a cable clutch you can adjust the cable to where ever you want it.
Hydraulic, Its staying where it is.
Old Apr 4, 2008 | 11:13 PM
D16SiHatch's Avatar
Default Re: clutch dont feel right, please help!!!! (Johnny-Red)
yep, what he said. just tighten the cable at the transmission bracket
Old Apr 8, 2008 | 01:16 PM
1320king's Avatar
i tryed but i cant adjust it to much more cause theres not to much play on the clutch arm.
but how much play should there be on the arm so my clutch wont be engaged all the time??
Old Apr 8, 2008 | 02:12 PM
97grnrs's Avatar
pedal should have 1/2 - 1 " of play at top ususally... adjust the cable accordingly..
Old Apr 9, 2008 | 02:07 AM
1320king's Avatar
Default Re: clutch dont feel right, please help!!!! (97grnrs)
i know about the pedal play but im talking about the arm on the trans. How much play is there suppose to be?
Old Apr 9, 2008 | 02:15 AM
civickiller's Avatar
i tighten the cable all the way with no play in the arm, mine grabs at the top, easier for shifting
guess you could say, tighten the cable till the pedal is where you want it to be
Old Apr 9, 2008 | 04:28 PM
1320king's Avatar
Default Re: clutch dont feel right, please help!!!! (civickiller)
so if i tighten it with no play on the arm it wont were out the clutch or the throw out bearing??
Modified by 1320king at 5:36 PM 4/9/2008
Old Apr 9, 2008 | 05:57 PM
schardbody's Avatar
you want a little freeplay in the cable. not half inch to an inch, but atleast an eighth of an inch or so. just enough to not have constant pressure on the clutch.
adjust it like that and break it in, then re-adjust it.
Old Apr 18, 2008 | 04:18 PM
1320king's Avatar
Default Re: (schardbody)
i guess thats what i gotta do. the thing is that the clutch starts to grab right off the floor and i cant adjust it anymore thats the best it can get.
Old Apr 18, 2008 | 04:21 PM
D16SiHatch's Avatar
Default Re: (1320king)
Well if its grabbing right off the floor that means the cable isnt adjusted far enough downward. Try turning the adjuster on the cable with vice grips once its to hard to turn by hand. My car after i bought it from my friend was doing just what yours is, so i tightened the cable up and i've never had an issue with that since. The clutch grabs right in the middle where it should.
Old Apr 18, 2008 | 04:42 PM
Johnny-Red's Avatar
Default Re: (D16SiHatch)
Sure your turning it the rite way?
Old Apr 18, 2008 | 08:42 PM
Hybridize's Avatar
Default Re: (Johnny-Red)
Sounds like the same problem im having. Keep us posted.
Old Apr 19, 2008 | 12:33 PM
1320king's Avatar
yes i am sure its turnd the right way, cause i had it the other way and i couldnt even get it in gear. ill try and show pictures and may be a video or somthing when i have time.
Beeracer930
Apr 25, 2010 09:51 PM
Radim
Feb 19, 2010 11:15 AM
Slvr_CRX
Dec 13, 2004 10:08 AM
lina sok
Sep 24, 2004 03:22 PM
rasta420
Sep 16, 2002 07:16 PM
