Taking bumper off (searched)
Old Apr 4, 2008 | 10:09 PM
prelude_93vtec's Avatar
Default Taking bumper off (searched)
How do you do it?
This is the only thread I have and it says to remove the whole bumper
http://www.hondaprelude.to/art....html
Old Apr 4, 2008 | 10:15 PM
russlan44's Avatar
Default Re: Taking bumper off (prelude_93vtec)
so the ones u probably looking for is theres one nut behind headlight in middle of high and low beam bulbs on each side, then theres also behind ur turning signal lights, 2 on each side, so take ur signal lights and get extended on size 12 and 12 for the ones behind headlight and 2 also by fender which u need an phips screw driver, the bumper will come off with reinforcment.
so total
2 phips screw attached to fender
2 bihind headlight size 12
4 behind turning signals
hope u understood
Old Apr 4, 2008 | 10:19 PM
street_ride14's Avatar
Do you really need someone to tell you how to take your bumper off ? Don't you think it should be common sense ? ...
( Front bumper ) Remove some bolts / screws around your wheel-well areas, under your bumper, near your radiator - under the hood, and the bumper should come loose .. then lift up and out ... don't forget to unclip your bumper lights from your bumper ...
... This does not need a write-up, nor should anyone attempt to search for a write-up on this matter ... this is common sense.
Old Apr 5, 2008 | 04:47 AM
Acidcrakker's Avatar
Well why are trying to remove it. Its really quiet simple. Its a bunch of those punches and a couple bolts.
Old Apr 5, 2008 | 09:41 AM
EteBoy's Avatar
Default Re: Taking bumper off (street_ride14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_ride14 &raquo;</TD></TR><TR><TD CLASS="quote">Do you really need someone to tell you how to take your bumper off ? Don't you think it should be common sense ? ... </TD></TR></TABLE>
What has common sense to do with the location of the bolts/screws holding the bumper in place. I for ex. had to look in the manual to find those bolts located behind the headlights. A write-up? Maybe not, but it helps to know where to use that wrench.
Old Apr 5, 2008 | 11:59 AM
Quit being a B!TC# and just answer the question. Just because you know it doesn't mean everyone else does. Thanks to the people who actually helped
Old Apr 5, 2008 | 01:25 PM
Infinity_Racer's Avatar
... This does not need a write-up, nor should anyone attempt to search for a write-up on this matter ... this is common sense.</TD></TR></TABLE>
whats common sense to YOU may not be common sense to everyone else...
Old Apr 5, 2008 | 09:28 PM
slamdlude's Avatar
Default Re: Taking bumper off (Infinity_Racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Infinity_Racer &raquo;</TD></TR><TR><TD CLASS="quote">
whats common sense to YOU may not be common sense to everyone else... </TD></TR></TABLE>
Yeah, it took me a while to find those bolts behind the headlight and I definitely don't consider myself a dumbass.
Old Apr 5, 2008 | 09:40 PM
K-Litt's Avatar
I actually did this today to replace my corner lights.
It's layed out pretty well on page 20-58 of the Service Manual.
Do you have a copy?
Old Apr 5, 2008 | 11:55 PM
Default Re: Taking bumper off (russlan44)
Well I got it off. Thanks russlan, i would of never found the ones behind the headlights
papi123
Honda Civic (2001 - 2005)
Jan 31, 2014 09:15 AM
dx_rex
Apr 30, 2009 11:05 PM
96_Accord_lx
Apr 23, 2008 06:53 PM
gcturismo
Jan 19, 2008 07:50 PM
Keith P
12
Apr 25, 2005 04:17 PM
