B16 Del Sol gears in a 92-93 LS YS1?
Old Apr 4, 2008 | 07:39 PM
unified112's Avatar
Default B16 Del Sol gears in a 92-93 LS YS1?
Ok.. My brother came up on a B16 Del Sol tranny, but the fourth and fifth gears are shot, completely unusable. He said he would prettymuch give me the tranny for me to do with what I wish. And I remember reading somewhere that the Teg LS (92-93) YS1 tranny can accept Hydro gear sets. So my question is: Will the gears from a 1994-1995 B16 Del Sol Hydro tranny fit the YS1 Mainshaft/countershaft? If so, I'd plan on using the Del Sol 1-2-3 gears, and my LS 4-5th. Any insight would be appreciated.
*Edit*
Yes, i've searched, but I haven't found a source saying which gears fit which main/counter shafts.
Old Apr 5, 2008 | 07:17 AM
HondaCivicSiR1's Avatar
Default Re: B16 Del Sol gears in a 92-93 LS YS1? (unified112)
ok first off yes a hydro gear set will fit in the ls,gsr ys1 case second is that i was told you have to keep the hydro trans parts together and the cable trans together you can not interchange them.i have a b16 gear set in a ys1 case also and this is what used to do the gear swap.i hope that this helps you
http://www.outlawatvclub.com/u....html
Old Apr 5, 2008 | 11:27 AM
unified112's Avatar
So you have to use the entire Hydraulic Mainshaft/Countershaft assembly in the YS1 case? Eh, shitty. Thanks for the input.
Old Apr 5, 2008 | 01:38 PM
Default Re: (unified112)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unified112 &raquo;</TD></TR><TR><TD CLASS="quote">So you have to use the entire Hydraulic Mainshaft/Countershaft assembly in the YS1 case? Eh, shitty. Thanks for the input.</TD></TR></TABLE>whats shitty about it?look for another hydro trans that has some issue and swap parts
Old Apr 5, 2008 | 03:36 PM
unified112's Avatar
Well, its shitty because if the gears/shafts were interchangeable, i'd have a free set of 1-2-3 B16 gears/differential. But, I guess just using the LS isn't all that bad. Again, thanks.
a1320honda
Northwest (Sales)
Nov 30, 2013 01:29 PM
dragooner00
Feb 4, 2011 10:09 AM
PureEF8
Oct 27, 2005 12:50 AM
themex77
Apr 27, 2005 02:55 PM
integraXTC
Dec 1, 2004 08:40 AM
